hello i've a question.
what will be louder.
an big round aeroport or an square port same inches etc etc and same freq.
i've an 18 cub box..2 MT 18's and 4 t30001bd's
my port at this moment is like the build in size of an 18' SX im using that hole as an port an maked it a lil deeper but is not loud enough on music.
will it be better if i make from that hole an square port ??
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
hard to say. only way to know is to try. some will say aeros over slotted/squared ports, vice versa.
if that aint loud enough on music, try a different tuning, possibly a lower one. also, it might be easy if you build those boxes with removable ports.
refs: chode69, superduper
i honestly dont think there would be a diff in spl. i guess its worth a shot though, you could try it.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
im glad you put the SUPPOSEDLY there cause that is def not true.
Edited by Slinky
DD M4
i highly doubt a 3db gain by switching to aeros. i have heard that aeros are more effiecient with the flow of air, so maybe a tenth, or a few tenths at the most...if any gain at all. but try it, maybe u will suprise us all.
i likes me some audio stuff...
yeah, 3 db is a lot of diff. it takes twice the power to gain 3 db. your not gonna gain 3 dbs just by an aero port.
DD M4
SUPPOSEDLY you can gain 3 db by going areo. But I don't know how true that is.
depends on the application, I have heard of people getting louder with areo's, then slot ports, or squared ports.
it's really hard to tell you what will be louder in your application, you have a wall correct? I only know of a few people that have used round ports in a wall, I tried round 2 6" round ports in my first wall, I didnt care for it, they werent areo's though.
its gonna be a test and tune type of deal, build, tune test, retunes test agian.
goodluck, keep us informed on your project.
David
i would def like to see how it goes though. i could be wrong here so i would like to see you try it.
keep us informed.
DD M4
thnx for all the info..
but i forgot to tell its already tuned LOW like 34 hz port freq and 44 hz car freq
i wanna tune the square port to 27 hz or an aero port to 27 hz but a want a lot of air moving what will be the best then and maybe the loudest ??
