Weightlifting/ Workout
I think your on the right track. Considering your body weight, the numbers look good.
Ok if anything i would think that my bench is lacking some. I just cant seem to build it anymore no matter how much i torture it.
Two weeks ago i was doing good, I was at 247. Shit hit the Fan and now I'm at 259.. Fuck! :(
I'm gonna try this again..
Love that Absolute Zero Monster though, Been slowly trying to drink that one only but the Red one is fucking Delish..
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
It happens. You know you can do it, just gotta stick to it. Absolute Zero is my shizz. I limit myself to a couple a week, though. Too many other supp's, wrong combination gets me feeling like a tweaker.
SMD Super Seller
My Feedback Thread
Guys I am 16 and 6th tall. I weigh 200 pounds. School ends in a month and I can't afford a gym pass right now as all money goes into my truck. So I can't use school gym. I have been running 1 mile every day for a month or so. I have cut out all candy and chips. ( I love) I need to lose weight so I can look good at the pool this summer. Please someone help me.. What can I eat? I cut down my portions a ton this week. I want to look ripped so bad!!
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Personally being younger (16) I am constantly needing more energy and protein with my rigorous works. I currently take max mass protein, 1,000 calories in the recommended serving. 65g of protein
Setup
Ride: Toyota Corolla
Headunit: Alpine CDE-123
Subwoofers: Fi Q 18
Amplifiers: Memphis 16 Pri-1000
Speakers Front: JL Audio TR650-CSI Comp's
Speakers Back: JL Audio TR650-CSI Coax's
I take that gainer for when i was trying to gain weight. I would take 3 scoops per shake and had 4 shakes in a day spread out as best as my schedual let me. Gained weight pretty fast so i had to stop. The stuff i have is strawberry and is 50g protein though not 65
Guess you don't want help.
Here are some goals for you, general guideline for strength and endurance.
Bench- body weight for ten reps
Squat- 1.5 times bw for ten
Dead Lift- 2 times bw for ten
SMD Super Seller
My Feedback Thread
sorry didnt go up far enough to see you replied,
My schedual at the moment is
5 day cycle
day 1-Legs
squats 2x10x135 + 225 till failure about 8
leg extensions 100x10,120x10,140x10
weighted lunges(30lbs per arm) around the room guessing about 40 total lunges.
Calf raises body weight 40,30,50 hold for 10 seconds on last rep
Last machine im not sure what its called but you lay on your belly and pull up with your legs. It is for the hammies. 80x10,100x10,120x10
Day 2-Chest + tri's
Bench press 135x10x3 somtimes im not able to get 10 on the last set and somtimes i can.
dumbbell incline press 50x10x3 (50 per arm) sometimes not able to get 10 on last set.
Dips 2x10,1x till failure]
Depending on what i feel like i will do skull crushers or tricep extensions
pushups till failure
Day 3- rest
Day 4-Back + Bi's
Deadlift 135x10 225x10 315 till failure which is about 4 (assuming the trap bar is 45 lbs as well)
cable rows 80x10 100x10 120x10
wide grip lat pull downs 80x10 100x10 120x10
chinups (underhand grip) 1x till failure
barbell curls with curl bar (not sure how much it weighs) 25s on each side 3x10
Hammer curls 35x10x2
Day 5-Core work, Some days run 3 miles
planks 3x1minite
leg lifts 20x3
weekand-rest
Some days i throw things in i usually dont hit such as traps,forarms, and abs. I need to think of a better schedual.
My main goals right now is just building strength
