is the power acoustik A2400DB any good for 2 12in fi ssds dual 1 ohm (no options) theyre about 800 watts rms but alot of people have been running hifonics bxi2006ds on them
the specs for this amp are
* 2,400 watt mono amp (Peak)
* 1,800 watts RMS @ 1 ohm
* 1,400 Watt RMS Rated @ 2 ohms
* 1 ohm stable
* Hi Speed Digital Circuitry
* Fully Regulated PWM Power Supply
* Four Way Protection Circuit
* 1 Ohm Stable Stereo
* Bridging Synchronization
* Variable Low Pass 50Hz-150Hz
* Variable Subsonic Filter 15Hz-40hz
* Variable Subwoofer EQ @ 45Hz
* Phase Switch 0-180
* Remote Dash Mount Low Level Gain Control With Cable
* Frequency Response: 15Hz to 150hz
* S/N Ratio: 100 dB
* THD: 0.5%
* System Distress Indicator
* Inputs Sensitivity: 200mv-8v
* Dual Mono Speaker Output Connectors
* Gold Plated Heavy Duty Power & Speaker Terminals
this amp seems perfect to me but i dont really have experience with them so can someone tell me whether or not i should go for it or not?
* 1 ohm stable
* S/N Ratio: 100 dB
* THD: 0.5%
great for the $$$ and will do about 1500@1 ohm... i heard of people having their PA 3000's for years and its still going strong... i'm sure the 2400 is the same..
well if alot of people are using the pa a3000db then i would assume its doing its rated wattage...
the pa a1800db, a2400db, and a3000db come with the same manual so im assuming theyre all built the same
it does right at about rated voltage, doesnt do more then rated but does almost exactly what its rated at
Yeah man, its a good amp. i have installed 2 a2400dbs in 2 different peoples setups and both times, i was impressed.
i also have two of the a3000dbs and i love them.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
  • Who's Online   0 Members, 0 Anonymous, 9437 Guests (See full list)
