There are pros and cons to running 1 big amp.
Yes it's easier to wire up and run. Yes it takes less space.
However, things can go wrong. It's easier to replace 1 amp out of a group and still have a semi working system, then it is to wait for the one to be repaired.
Draw wise, the 8.1 and 4 HF-2500's would be about the same. On a daily system I would suggest 4 amps over the one 8.1
Well..hmmm...I would listen to Bill, on this...David and he seems to know their $h!t pretty well.
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
The major reason, (and I can speak with plenty of experience on this) is god forbid you have to send an amp out for repair. It sucks ass to be without beat or have to miss comps because you have nothing. At least with a group of amps, chances are you can still have tunes and or get points at shows.
Nothing sucks more then driving home from a show or comp without tunes because your having issues.
I would say multiple amps, run each at 1ohm or higher, less amp draw and a little more head room.. It is easier for a amp to run just one speaker at 1 ohm, than four speakers wired at 1 ohm. I believe that you can hear a Dynamic difference..
I'm running one amp at 2ohm currently and hope to be running 2 each at 1ohm soon..
What I have learned with big power is, if you can do it, Get as much if not more alternator to match your amp draw that way your not playing of your Batteries. This will also keep your volts up and more watts.For every day use this is nice.
And it is easy to tell, you know your resting voltage of your batts, if your voltage goes lower than that you are using all alternator power plus also pulling from your batts.
Example: 1 stetsom 7K2d at 2 ohms, Batts resting at 13.1
Exp1...1- 250amp mechman + 1-stock 60-80 alt on music Voltage drops to 12.9 volts....pulling off balteries..
EXP2- 2-250 amp mechman + 1- stock 60-80 alt on music Voltage drops to 14.1 vollts, more watts and more dynamic beats...
Burps
EXP1 I didn't even bother
EXP2- at 2-0hm voltage 13.3
at 1/2-ohm voltage dropped to 11.1.. where I stopped testing before bad shit happened..
With the voltage drop abusing the amp at 1/2 is not even worth it untill I get my third mechman hooked up, the power gain is minimum...
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
soundigital 12kd(i know its outside of ur budget, but its soo nice)
7.5v-18v!
12000 - 12.6v rated rms
18000 - 16v
20000 - 17v
sweet resetable multi protections with an led for each offense.... tiny foot print... assman will have 2
get this amp and u have room to grow
x2
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
x3 on the soundigital...... solid amps, ppl need to change it up lol
if i had the money i would get on of the soundigital.
Head Unit: Pioneer Premier Deh-600ub
Front Stage: (2) Whip Audio 8" Mid-Bass (2) Whip Auido 6" Mid & (2) Audiopipe ATX-3720
Amps: (2) Cadence TXA300-4 :D
Amp Kit: Knukonceptz
Coming Soon: already ordered
Sub: 2 DD T1508's
Amp: Sundown saz-1500
Tired of the lag? Come get crunk!
