Just for reference the Sundown SAE1200D I just got has 5 30 amp fuses and is rated at 1200w @ 1 ohm. I heard it's actually capable of about 1500w.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
ok so lets go ahead a take another step into reality.... what fuse rating do i need to be looking for to get the kind of power that im looking for?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
or you could get the amp put in your car and clamp it and see what it does.. :good:
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
x2 on derrick, that usually comes up pretty close...most amps are lower though
500amp on a rockford 4000rms amp (although they usually hit 4600-4800)
160amps on my 1500rms amp
75amps on my 600rms amp
keep in mind that effeciency drop from low impedance can cause a decrease in output...i've seen a few rockford t3k's do more at 2 ohm than 1, and dont even think about crown amps (which will triple the 1ohm output at 6ohms)
Team DC
It's a good guesstimate that fuse rating x 10 will be it's rough power output. 100a = 1kwatts 200a = 2kwatts & so on.
Thats usually how I do it aswell.
My Rockford birth sheet says 1628wrms with a 150amp fuse....but then again I wonder how reliable they are.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
u cant go by ratings... even RMS.. that gives a ballpark figure yes, but when u hook ur sub up to it in the box and play it and measure your impedance rise and your actual power output its sometimes close sometimes not.. check n see youll be suprised..
2007 Chevy HHR LT
UNDER CONSTRUCTION
SS amplifiers, not what they used to be. ( so sad too, they used to be the shiz of the shiz)
yeah with 4 subs i immagine impedance rise would be insane....
well i was hoping i could find a cheaper alternative... but im thinking im just going to have to break down and buy the aq2200d... because it seems like the cheapest thing that will actually do rated power....
3 Kinetik Hc2000's
Dual 200amp alts.
