Quick question, I need to get my system tuned properly but like everyone else I want to do it on a budget if possible. :01nocomment8so: Soooo I had an idea, I don't have access to a Meter so I thought the next best thing would be something like the audio control unit (don't know the model) with the SPL meter. My thought was along the lines of a body fat monitoring scale. It may not be very accurate as to the level but if it changes from 1 DB level to another it should be right on, at least that is what doctors tell me about the scales; may not be accurate as to exact body fat but if it goes down a percent your down a percent.
Also I believe the proper procedure is a sealed box in as close to the exact location of the build along with a test tone CD and run through the spectrum and mark it on a graph. The highest frequency is your resonant frequency and what your box needs to be tuned at or around.
Chime in guys and let me know
Starting From Scratch!!
BUMP! :search:
you have a sealed box?
if so you can't CHANGE your tuning. your resonant frequency will be based on the sub and cabin gain.
I'm pretty sure he's referring to changing the frequency of the sound waves from the source and using that figure to build/tune his ported box.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
You technically can change the tuning by adding fill to the box and or using bricks & stuff to change the internal volume.
But, its my understanding that a 1x1x1 sealed box is used to determine your tuning frequency.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
^^^^sorry. i misunderstood his post. it was late. :lazy:
Yeah I have a ported box in the car but it was built to the manufacturers specs not my cars. I was planning on using the sealed box to find the frequency of the car and then build a new ported box to those specifications.
Yes sir, at least that is what I also heard and was trying to check here. I gues just run a test CD that blows through the freq. range and record what I hit. The issue is that I dont have a meter so I was hoping something like the Epicenter 160 with the SPL mic could at least let me know what freq. are higher or lower.
Anyone else got an idea if my Bodyfat scale/Epicenter analogy is correct?
I wanna know how this goes bc I built a box for 2 RE 15's based on RE's specs which was 36 hz. Both time the truck has been metered it peaked at 41 hz. So wouldnt a 41 hz box be louder since it matches the trucks resonant frequency?
Current System:
Pioneer 6900 HU
Bass:
No thats wat ur current box is peakin at.. change the tuning and your peak will change..
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Well we have been doing this for years and years.
Build an enclosure with a flat response. A nice sealed box would do the trick.
Play varying frequencies, dB Drag CDs have sweeps you can use.
Use an SPL meter with a peak hold and whatever frequency hits the peak, is what you want to tune to.
The Term Lab meter will be your best meter of choice since it reads the most consistantly and varying air temps do not effect at what frequency it will read more sensitive at.
Also, the TL has an Oscope that will tell you at exactly what frequency was the highest SPL.
This is really a 20 year old technique, and it still works well to this day.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
