getting my truck painted in december....wanting to find a cheaper way to black out the tail lights....how does it look with the gloss paint just laid over the lights like the rest of the truck?
4 - 15 Sundown Z v.2 @ 35Hz
2 - AP3000D
2 - RF Power Punch 6.5 Comps
2 - RF Power Power
1 - Kinetic KHC2000
3 - Kinetic KHC2400
Iraggi 300A
Knu Wiring
I have a funny feeling it would look like utter crap. JMO. Unless you did the prep work on them, in which case you would probably end up spending about the same amount unless you would black them out yourself. I had a forum-mate on another forum do this. I'll see if I can't find the link for you.
EDIT: Here you go
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
ya...idk. im really looking to get them to be straight black without having to do the metal work ya know? maybe ill just end up buying the blackout covers and then disconnecting the tail lights.
2 - AP3000D
2 - RF Power Power
1 - Kinetic KHC2000
3 - Kinetic KHC2400
Iraggi 300A
Knu Wiring
google "nightshade paint" Its a can paint made specifically for blacking out tail lights. Used it on mine and worked great.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
So you're looking for show car levels of black? Not street car levels?
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
ya, im getting the 60" fire and ice led light bar for the bottom of my rear window. use that as my tail lights
2 - AP3000D
2 - RF Power Power
1 - Kinetic KHC2000
3 - Kinetic KHC2400
Iraggi 300A
Knu Wiring
Mix some black in clear coat, keep on putting on layers untill you get the level of darkness that you want.
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
its a 2000 f150
paintin it straight black in the winter
should i put a clearcoat on after the last coat of the nite shades? i should do like 5 coats....i just want it blacked out completely
2 - AP3000D
2 - RF Power Power
1 - Kinetic KHC2000
3 - Kinetic KHC2400
Iraggi 300A
Knu Wiring
its a 2000 f150
pay to get it shaved if your not going to use them at all..
you will like it much better
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
