okay i have a 2002 lexus is300 automatic transmission.
the car was taken care of by previous owner and was garage kept and was in perfect condition when i bought it month ago.
I took it to the track near me which is a 1/8 mile track and i run 10.4 to 10.6 at about 64-67 mph... if my car is rated for about 7.4 from 0-60 why does it take over 10 seconds to do 1/8 mile at 65?
Could be a number of things, like conditions at the track, temperture, track prep, ect. Street numbers and track numbers are two completely different things. Lots of practice and good track conditons is essential. Looking in the other direction could be the car as in things like fuel filter, air filter, plugs / wires, little things like that can hinder performance alot, even though you say last owner took care of it, never know how many miles can be on that stuff.
the track isnt very even and they spray a lot of that grip stuff almost halfway down the track... i would guess its the track then...
and it was about 90 degrees outside...
90 degrees is pretty hot, under hood temperature would be more than usual and hurt performance, when they test those numbers for cars, like 0-60 and quarter mile times its almost always in perfect conditions.
Well I give you a slight idea of how much temperature affects performance.
Its was 97 outside my brother was having overheating problems b/c of his large intercooler and he ran a 14.9 untuned(terrible)
It started to get dark and it was 73 outside he let his car cool down turned around and ran a 13.7 untuned
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
02 is300 I believe is rated at 215 hp and weighs a tad over 3000 lbs. Its not really going to be a super quick car. adding to the fact that its an 02, and not brand new also takes away some power, even if it was well maintained. The track could also add to that factor, as well as if the times posted were from a manual is300 or an auto. I read somewhere that the manual is300 is faster. forgot where though.
But I rather be a pro at being myself
Than be an idiot trying to be somebody else
well took car this morning to a street where i could stop and go 0-60 and i ran it in 9.4 that was on the street but i am going to be changing all the spark plugs and the fuel filter then will retry it... i might get the spark plug wires changed also...
Would it surprise you if the factory ratings were a touch inflated? They use the best performance #s that were done under the best possible conditions.
As fro the track conditions temperature, humidity, and especially elevation play a big role in track times.
everybody knows that automatics arent as fast as their manual counterparts.
you arent able to dig as deep into the RPM band in an automatic
my stock 95 honda civic (automatic) with only 102hp can do a 0-60 in about 8 seconds, so weight has a lot to do with your numbers too
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
