Both will add structural strength to it. Doubling should add a little more strength, but as long as the majority of the baffle is doubled, it's going to be a lot stronger.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
flush mounting the subs doesnt add strength, its just for a clean look. the double baffle will add a lot of strength though.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Thats wrong, Flush mounting = double baffle which in turn is just as strong and cleaner than a double baffle.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
flush mounting does add strength to the baffle, the only difference strength wise is the subs have less wood to be screwed/bolted into, but with the extra wood around it, it will not flex so its not a problem. Both virtually do the same thing except flush mounting looks a lot better.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
BINGO. Also, if your sub can strip out 8 screws at a time from 3/4" MDF then you should be quad baffling that bitch! The ring where the woofer is mounted is the only point of "weakness", & I wouldn't even call it that.
Edited by Chris
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
  • Who's Online   0 Members, 0 Anonymous, 992 Guests (See full list)
