I know copper is the preferred material to make bus bars out of but my question is, is there really a difference in conductivity between aluminum and copper. Also, if I were to use aluminum would I notice a significate difference in voltage or anything over using copper?
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
If you notice most entry cables for houses are aluminum. If you go with the equivalent aluminum, you must increase the size (diameter) of the wire than you would for copper. The reason aluminum is used is because it's more cost-efficient to run the aluminum.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
I've used 1/4" or 3/8" by 1-1/2" buss bars and never had any problems with voltage.
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
dont mean to thread jack but for copper buss bars, how thick should it be to be efficient?
Depends on the size of the bar (thickness and width), they have amp ratings for them. For example the buss bars Max has in the back on the batteries, those are rated at 1,000 amp's
Edited by SIETE_CINQO
Random vids of the Avalanche My link
Team Bass-Hz
