e-mail sent !
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
put a clip light on the bass remote and you will take all of audioque's sales. :D
love that feature :give_rose:
DC.jpgDC POWER
It is laid out like the Brazil amps - but is not the same type design.
You will need a Maxx-Link to strap these.
But you can get 3kw out of a pair easy. I am reluctant to release all of my power testing data on them as I put bigger fuses in to do it... rest assured these are VERY powerful amps.
Figured.
And DAMNIT.
Oh well, 1Ω apiece it is.
I know you may be a little biased, but, I have a rise to 3.5Ω per sub.
Can I expect these to outperform the AudioPipe 3000 I have now?
November is so far away... :sorry:
very good amp, I may get on this one too
I have a board that I believe to be equal to the new Audiopipe AP1800 model... as it is built just like the AP1500 but with two extra output FETs - I tested it vs. the SAE-1200D:
For the sake of this test I just turned everything wide open just to see when they quit making power. THD was not a factor at all, just wide open. Obviously this is not the ideal situation -- I may send them to Chris so he can use some of his equipment to do a test using a scope as well.
The amps are fed with a 4 awg and 8 awg wire in parallel reduced to 8 awg so it will fit both amps (the 1800 won't fit our 4 awg lead directly as it is tinned).
Test load consists of two Nightshade 12s wire to 1 ohm and the tone is 60 Hz.
Posted Image
* SAE-1200D on the bench
http://www.sundownaudio.com/misc/1800-watt...0D/CIMG2617.MOV
* Power Test
http://www.sundownaudio.com/misc/1800-watt...0D/CIMG2618.MOV
* Output Voltage Test
1730 watts
59 V
29.3 A (calculated)
2.01 ohms (calculated)
12.68v power supply
Posted Image
Posted Image
Posted Image
12x Power Supply Fets
10x Output FETs (AP1500 has 8)
The two caps = a little more capacity than the four in the AP1500D. These are 4700 each and the AP1500D has 4x 2200.
Posted Image
* 1800-watt on the bench
http://www.sundownaudio.com/misc/1800-watt...0D/CIMG2621.MOV
* Power Test
http://www.sundownaudio.com/misc/1800-watt...0D/CIMG2622.MOV
1440 watts
57.1 V
25.21 A (calculated)
2.2 ohms (calculated)
13.1v power supply
SAE-1200D produced ~20% more power... and this 1800 has an extra 2 output FETs above the AP1500D.
An SPL test may be more revealing... I may see if the 1800 will stay on in the Jeep at 1/2 nominal -- my rise is to just above 1 ohm.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Kickass little amp there :ph34r:
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
