loganberry's f150 build-- big changes coming soon
he said there supposed to be a matching pair, this one is also supposed to be doing 14.8-14.9 but its not so idk =\
What is the new alt charging at then?????
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Oh I thought you were gonna say something like 13.8, that's not too bad then. As long as it's holding at 14.4 your good.
1 XS Power D3100
Audio Control LC6i
Stock Deck
ill drop to at the lowest 13.6 full tilt but it pops right back up and it keeps it up my batteries are all resting at 12.7-12.8 so its doing its job :) im happy with it
What series alt do you have Logan? Is it a 3G, 4G, 6G, or something else? I may have a little trick for you to up the charging voltage.
1 XS Power D3100
Audio Control LC6i
Stock Deck
to be honest i have no idea at all lol...maybe rob can chime in on that
Well I'll tell you anyway what can be done to raise charging voltage by .6 or so volts. It was on the Ford 3G, 4G, 6G and a couple of other alts that I read from a reputable alternator manufacturer that you could soldier a 6 amp diode inline with the yellow sense wire before it goes into the alt plug and it will charge around .6 volts higher than what it normally does. So.... that would put you right at 15 volts. I have never tried this but the manufacturer said it will work with no issues at all. I wanted to try it with my stock Ford alt in my car, but could never actually get to the wire that I needed to get to. Maybe Rob can answer the question on if this will work period without damaging anything.
1 XS Power D3100
Audio Control LC6i
Stock Deck
you're the luckiest mofo, you keep getting pulled over and keep getting let go......not being a minority must be nicefyou3.gif
white in cali IS the minority .... right logan :D yer white right? LAWL
^^ depends on what part of cali you in...
Hustle hard, Stack paper,
It's alright, ya'll haters,
It's nothing, We major,
You see me, Hi Hater! =)
~ Manio
  • Who's Online   0 Members, 0 Anonymous, 1605 Guests (See full list)
