loganberry's f150 build-- big changes coming soon
I just connected that even while handling 1.5" 160 pound wood Logan will still where his damn filp-flops :rofl:
EDIT: and even more ironic is I am the one that gets the finger smashed!
Wouldnt be thehoe92 without teh purple
whats the specs on this box logan?
you guys should just wrap it in black carpet or just bedline it or something.
the paint is not permanent, not even close, i just couldnt pass up a 2 for .50 deal at home depot on the black paint, had to do something waiting for resin to dry
its 8 cubes after displacement, 35hz tuning, and strong as an ox
edit: box will not have carpet or anything like that on it, i was told cloth materials absorb sound, im needing to squeeze every tenth outa this thing as possible
double edit:for spelling
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
Good luck with it. With the amount of power and the subs your running I'll be very surprised if you don't do at least a 150. Hopefully that everything foward design works well for you. Is there anyway possible that you could fire everything up to try out?
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I'm no Pro- but i did a 150.6 with a bare wall and one amp.
then added a layer of thin foam and blue cloth on the wall
then added a second amp and did 150.3
only thing i can come up with is that the carpet/foam took more away from the score than the amp added. :search:
The space under the box looks like a cluster of phase and cancellation- why not put the box on/just on top of the floor?
Lookin fwd to ma demo :good:
-Drew
uhoh_45 said:
Good example is why trunk cars sound better port+sub back instead of sub+port fwd (unsealed, just sitting in the trunk)
the waves coming off teh woofer and port are not ONLY going forward, but up and back and down and back. He may just sound better/cleaner/or louder on the floor.
but you never know unless you experiment
-Drew
this design is good because he can put the port on the left or the right side of the truck with either the subs forward or up so there is a lot of experimenting the only thing limiting him is whose going to help him move it :P
