tacomabanga1986 Posted August 28, 2009 Report Share Posted August 28, 2009 here's mine LCD feature Specification Display size 17-inch (43.2 cm) diagonal and viewable image Display type Thin-Film Transistor LCD active matrix BriteView technology Input terminal VGA 15-pin D-type connector DVI-D connector (cable not included) Speakers 2 integrated speakers 1 watt each, 2 watts total Scanning frequency Horizontal scan range 24-83 KHz Vertical scan range 55-76 Hz Native resolution (H x V) 1440 x 900 Contrast ratio up to 600:1 Response time 8 ms (on-off) Pixel pitch 0.255 mm HDCP (High-bandwidth Digital Content Protection) Support for HDCP enables the monitor to display HDTV resolution if connected by the DVI connector. A monitor without HDCP support, or connected by analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV. HDCP is also a content protection system. The goal of HDCP is to prevent transmission of non-encrypted high definition content. Power source - AC/DC adapter Input rating: 100 to 240V~ Power consumption: <37 W in operating mode, <2 W in sleep mode Operating environment Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C ) Humidity: 15% RH through 90% RH (non-condensing) Storage environment Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C) Humidity: 5% RH through 90% RH (non-condensing) Dimensions H x W x D, including base: 14.3 x 16.2 x 7.2 inches (36.4 x 41.4 x 18.4 cm) Weight Unpacked: 5.9 lbs (2.7 Kg) EMI standard FCC Class B Mounting Standard VESA 4-hole 100 mm x 100 mm EPA Energy Star As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency. Quote here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
inm Posted August 28, 2009 Report Share Posted August 28, 2009 42" Samsung HDTV when watching movies/playing games/goofing off. The built in 15" LCD when doing school work. When at my brother's house, I use his 52" HDTV for movies and goofing off Oh yeah, my other laptop is 17" (I think...) Quote On 2/28/2013 at 2:52 PM, Chaise said: "Now spread your butt cheeks so I can zap your asshole." 2008 Subaru Forester XT Link to comment Share on other sites More sharing options...
SQMonte Posted August 29, 2009 Report Share Posted August 29, 2009 22" Lenovo L222 widescreen Quote Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f Link to comment Share on other sites More sharing options...
1992Chevy K1500 Posted August 29, 2009 Report Share Posted August 29, 2009 My parents: 22" eMachines and 46" LCD tv. Mine: 15" compaq laptop and 15" Sony. Quote My comp setup (Not bad for what it is): HP Compaq Presario V6120US laptop with: 15.4" widescreen AMD Turion 64 X2 1.6GHz processor 2x1GB stick DDR2 SDRAM (667 Mhz) Seagate Momentus 500GB SATA HDD 128MB shared video memory Windows 7 Home Premium 64 bit 12 cell Lithium Ion battery (actual battery usage time: 6 hours) What it does: On a USB 2.0 Wireless card Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted August 29, 2009 Report Share Posted August 29, 2009 I have a 20" LCD for my computer, but I could hook the computer to my 60" Plasma Sony. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
littleitaly1990 Posted August 29, 2009 Report Share Posted August 29, 2009 1920 x 1200 17" laptop monitor....1080p 42" panasonic plasma also for when I'm feeling frisky. 1080p or above or no go for me Quote A vitrolic, megalomaniacal sadistic psychopath. Link to comment Share on other sites More sharing options...
Bunker Posted August 29, 2009 Report Share Posted August 29, 2009 56in samsung Quote J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer Link to comment Share on other sites More sharing options...
98crewcab Posted August 29, 2009 Report Share Posted August 29, 2009 (edited) i can hook up to my 50 inch Samsung HDTV....but im running on my HP laptop 17" widescreen HD and i have a 17 inch LCD on my other computer dude, I have the same 50"......I can plug right into it?...sweet! I just have the P O S dell monitor. Think its a 17? maybe smaller. would be sick on the 50" Edited August 29, 2009 by 98crewcab Quote 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk! Link to comment Share on other sites More sharing options...
J00bles Posted August 29, 2009 Report Share Posted August 29, 2009 (edited) most tvs now a days have VGA and HDMI ports on them, which allows you to hook a pc up both my tv and my computer monitor are Samsung 19" LCD's. they're plenty for me Edited August 29, 2009 by J00bles Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel Link to comment Share on other sites More sharing options...
vexproductions Posted August 29, 2009 Report Share Posted August 29, 2009 32" lcd sylvania tv Quote Link to comment Share on other sites More sharing options...
