enclosure for fi bl 15
Jville140db
so i finally decided on a sub fi bl 15 fully loaded and was wondering about the box the dimensions i have are as follows EXT w-45.5 h-17 d-12 my port will be h15.5 w3 l28.5 which is 46.5 in of vent area tune is 33 hz and volume is 3.4 cu ft all corners will be 45 and the box will be resin coated on the inside will this be big enough and what kind of numbers should i expect in a trailblazer with 1500 rms going to it off of a bxi1606d or do you think i should upgrade the amp as well thanks for any help
EDIT- BTW Thanks to Zaxfire69 can't wait to get the sub.
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
any one at all
Currently in car
no just one 15 and the net internal volume will be 3 cu ft after sub, port and bracing displacement.
Currently in car
i do believe that 3 is kinda small my friend.. i was runnin 1 fi ssd 15 in my maxima for a while and that what 4 cubes and sounded great.. i think 3 is to small though.. just my opinion
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
i might be able to pull 3.5 maybe 4 if i lose a little of the area i was trying to save think that would be enough im looking for a daily box that will play fairly flat
Currently in car
  • Who's Online   1 Member, 0 Anonymous, 9954 Guests (See full list)
