IA 20.1 for me too. If I were to swap out sundown for either of those it would not be for Crunch I think it would be trading down. The IA would at least be an even trade or a trade up.
that is very interesting...
Agreed.
My Official Feedback Thread
PSN - tech2332
Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
I'd get the IA20.1 over the GP3kD any day.....iirc the 30kd only does 2800wrms of clean power.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
so maybe i should get a sundown 3000d for now and wait till i can get another one...??
That'd be a good idea. IIRC, that amp puts out 3300 watts with a steady 14 volts.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Not true, that amp will put out a clean 3500 at .5 ohms on good electrical. There are test results on Termpro if you want to see them. I have my own test results of it on .5 nominal rising to 1.26 reactive and making 2800 watts with a voltage drop to 11.9 volts. If you can keep that voltage above 13 on a burp hello 3500 watts. This was with the gain set a little above 3/4 and no bass boost off of a 2 volt preout deck. That is why the gain had to be set so high. They are strong amps and will put out power if you can keep voltage going into them.
On the other hand whoever said IA is an upgrade over Sundown is crazy! First of all the amps are made in the same factory. Second of all Jake from Sundown and Nick from IA will tell you that neither of their amps are better than the other. They are good friends and both of them make a very nice product. I wouldn't say that one is better than the other at all, I'd love to own both and I do love my Sundown :)
Edited by Nightshade
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I used to own a (Paperweight) Crunch Powerzone P1500.1 in my Lincoln and that thing was a joke, I replaced it with an old Memphis amp I had just to have some beat. I would personally go with Sundown but of the two I would rather use the IA.
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
fyi, jacob is selling 4 sundown 3000s in the sundown section for $625 each..which is a steal!!
and between crunch and ia, id go with ia
i likes me some audio stuff...
