Blown Fuse?
Jared420
actually what are those red wires on there for? thats your prob. you dont need those
Edited by Slinky
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
nah in the first picture the blue wires are how its wired now
the red wires i put on to ask if that would be a better way to wire them and then someone told me to series wire it and i made the 2nd picture cuz i wasnt sure if that was series or not. but in the first pic the blue wires are how my sub is hooked up but when i bridge it to the amp the fuse blows
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
x2 on the ohm problem, if u have the manual for it, check 2 make sure your amp is bridgeable...some arent....also check to see what the ohm load can be on bridge mode...many amps can only handle safely a 4 ohm load bridged...i hope that helps a little...
yea i have the manual it says 460 watt rms bridged @ 4 ohms
230 X 2 @ 2 ohms
150 X 2 @ 4 ohms
says it can be bridged
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
i dont think that the amp can take a 2ohm load when bridged, which is what happens when you wire the subs in parallel/bridged, which is why the fuses keep blowing,wiring in series wont help it either.
i thought that bridged it would be a 4 ohm load ... i dont really understand much about ohms can someone give me some basics about this . i was pretty sure my sub is a 4 ohm sub and my amp manual says it can be bridged at 4 ohms and get 460 watts rms
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
your sub is a dual 4 ohm sub which makes it 2 ohm. then your trying to bridge it.
In stead of bridging it, run what you have to the left + and - .. only use that 1 channel..
and thats all your amp has.
alrite but does it make a difference the way i have the sub wired inside the box? i have 4 wires directly from + on one side of the sub to the amp the + on the other side and the 2 negs. i was told this is fine but would series or paralell wiring be a better choice?
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
what you are doing now is called parallel, which is the correct way for the amp.
