DC sub up and playing.
Very good quality looking craftsmanship on the enclosure man, but what did you finish off the kick panels with??
Pioneer AVIC-N2
I still have to work on those. I want to get the box designed because it has to be dismantled and rebuilt in the car. i have about 3 weeks left till i get my subs and amp so I will have time to get those done. now that its cooling off it will be a lot better...
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
going good bro. 3 10s ain't a bad choice ....... might have to consider that in my wife car.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I went with 3 mainly because my port idea would not work. but it turned out better in the long run. now I can run the amp at 1.33 ohm instead of having to keep it at 2 ohm for daily and switch it over to 1/2 ohm for comps.
Thanks everyone for the commets..
PPI dbl din
DC Level 3
DC audio 2.0k
Looks amazing man.
Honda Accord 4 Door
Current System -
(2) 12'' Mtx Thunder 5500's
(1) Alpine Mrp-m1000 @4Ω
(1) Pioneer Deck Deh-3500
(1) American Legacy 1.0 Farad Capacitor
(1) Stinger Voltage Meter (Blue)
Big 3 Knu 1/0
Box 3.4^3@37hz
My Soundfx Logo I came up with.
Posted Image
Posted Image
now cutting out the team name. Tought about just doing a sticker but why not. Its go big or go home right.
Posted Image
Finally got it cut out.
Posted Image
This is just 1/4" foam board but its neat you can apply fiberglass to it and with a little bit of work. jk a little more than average you can have raised lettering. I did some thing just like this back in like '98.
PPI dbl din
DC Level 3
DC audio 2.0k
i like how this is coming a long
i keep for getting to ask you when is this expected to be finished?
3 to 4 weeks
PPI dbl din
DC Level 3
DC audio 2.0k
