At my last competition I did a 145.7db at the passenger dash with my driver door open with the equipment in my sig.
So I am not quite sure what the actual power output is on my T1001bd but it is definitely a sweet amp.
I just purchased a Sundown Audio SAE1200d amp and was wanting to know with exact same equipment minus the T1001bd and add in the SAE1200d if you think I can get into the 146 range?
I am a little confused because the Fosgate Amp is 150amp fusing but only rated at 1000 RMS @ 1ohm
The Sundown SAE1200d is 150amp Fusing and rated at 1200 RMS @ 1ohm
I have heard a few people say to take Fusing x 10 to get your hypothetical RMS output of course minus impedance rise ect...ect..ect
that would mean that these amps would be right around the same... I guess I will know more when I get the amp and hook it up and meter it but want to know a few of your thoughts on this.
A little more info:
Name of the song in the video is:
Danity Kane - Show Stopper
Also another question... things that I notice since I have been playing a few tracks.
When you are playing songs that are close to your resonant Frequency do you get less voltage drop?
Hrmmm... I suspect the amp alone wouldn't make much difference but I suppose we're only talking about a few tenths.
You would be better off playing with things like seat position, sunvisors, aircon vents... that kinda crap that costs $0 and could potentially gain you more.
Can you move the box around at all?
10.x volts fo' life!
Well I have about 8 inches of play moving it forward or backward.. no room side to side.
Start with that and seat positions. I bet you'll get over 146 just tweaking those.
seats all the way up lean forward.. cross ur legs, hug around the steering wheel and push play... oh and turn ur defrost on ;) jus some things to try
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
i bet u $10 that version of danity kane is clipped
i cant believe u have a 145 w/ difference sized subs
Should have made the show so I could make a believer out of you... Ask CrumpT1 and Slapuhho about it they got to sit in it and hear it. I got another one for you that hits 145.7 different song Same day my third run. not clipped and not distorted and I believe this is your song unless you clipped it when you made it :) could have been Bigpimpin also I am not quite sure.
I actually played this song to get a laugh out of people and it worked... I was surprised it hit at my peak also.
Edited by Hotdog
I could see it, i mean as long as he has them in seperate box's, tuned around the same i could see it. Still would be pretty tough to do though.
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
That is exactly it.. dual chamber box tuned to the same freq
Edited by Hotdog
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
