What is ur dream system
1 - Pioneer AVIC-Z1
8 - Digital Designs M4
2 - Digital Designs S4a
8 - Digital Designs Z15
2 - Audison Thesis TH K3
2 - Audison Thesis TH K2
2 - Powermaster 482038SPL
9 - Odyssey Battery PC2150
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
My dream system? Well, how's this:
Posted Image
Posted Image
Posted Image
Box was designed for (4) RD SHW 18"s running off of (2) Stetsom 14K2D's and powered by (48) Kinetik HC3800's. It would fit in the bed of an early 90's Chevy full size pickup with fleetside longbed (would have to lift it enough to remove the wheel wells). The box is 40" high by 70" long by 60" wide.
I've had a few hours to design it. :)
I also designed one for pure burps only. It is the same, just with (4) Stetsoms instead of 2.
EDIT: forgot to mention, the wood is 2" think (double layered 1" wood for strength.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
should be in the offtopic section, im sure a mod will move it
actually i would say it should be in the "General Audio" section.
My dream system would be 4 lms ultra 18's in a blowthrough in my current truck, powered by two sound digital 12kd's. Quad dc power alts. 8 powermaster d3100's, and all the kicker ss 6.5 component sets to balance it out.
Big system I actually plan on starting on next summer...4 AQ hdc3 aluminum coiled 18's powered by a soundigital 12kd with tripple alts, shuriken batts, and 8 runs of 2/0 welding cable in a blowthrough.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
Mine is 16 Soundstream XXX-18's , 16 XXX-15000D amps, 16 Rolles Surette 8v Batts, 5 DC alts, all in an Armored Truck...hehe try to make that thing flex
Team Soundstream
Team Xs Power
Team Secondskin Audio
Team Mechman
05 Yukon Denali murdered out on 24s, with the following -
8 15" TC 5400s
8 Zapco 4kws
Macintosh 4 channels
Hertz speaker/mids/tweets
Ultraflex welding power wire + Stinger pro speaker wires/RCAs/etc
4 400amp Ohio Gen alts w/ Northstar batts
Walled behind the front seats in a low tuned 4th order
Pioneer AVIC-N2
1 cerwin vega 12 on a visonik 200 watt amp, ill be getting like a 160 wit dat :D
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
