Time for EVO 2
First of all, I put everything on paper First. Drawed it all out how I wanted it, with some more pretty roundings in it.
After that I milled some discs, and glued them on each other, and put in an M5 shaft.
Placed it all in the drilling machine, and put a little plank underneath. If you look closely you see a hole of 5mm in the plank
Placed the drill below, and the little shaft is now in the hole. I did this so the MDF Block won’t be able to swing out of it’s axis.
Once this was placed properly, I screwed the drill tight, so it couldn’t get any higher or lower anymore.
Started with the abrading proces again, and this time I didn’t use a sanding Block.
This model looks a lot better
Then I knocked in the front little disc with 3 little nails. This little disc also has a small side where the logo falls in.
Abraded it all
Then I took away the last ring, and used the “klockdrill” to empty the inside;
Once I saw I was almost at the limit, I glued the final ring back on there.
Every time I replaced the drill by a smaller one, and extracted layer by layer.
If you see how I’ve done this, you must be sure you don’t drill too far, or you’ll have a hole in your hand.
The whole family
Such a fierce build
A YO STEVE, IMA LET YOU FINISH AND ALL, BUT THIS IS THE GREATEST BUILD OF ALL TIME
:friends::friends:
i think after reading this write up it's potentially ruined every other writeup lolz.
I don't see how anything else unless done by a team of professionals can top this.
THX MATE
:good::good::good::good:
Make it out of aluminum :drinks: OR carbon :good:
:+1::+1::+1::+1:
i love you
:bartmoon::bartmoon::bartmoon:
Such a fierce build
Keep up the amazing work
THX DUDE's :friends:
Now the cone worked perfectly for me, I just need to make some aluminium toggles to Mount it.
I drawed some models first, and then made one out of 10mm thick MDF.
I drawed it out on an aluminum plate of 6mm thick.
I sawed out the toggles, and pasted them on the MDF, and held them against the copy mill with this result.
You can also see that I modified the model a bit, on the front. I made it rounder, so it looks a bit like a sled now.
What you can also see on the alu, is that I used a new mill. The sides are more smooth then usual, but some polishing will still be necessary.
This aluminium plate I made for the PPI, I modified a bit, so I can still use it in the new set-up.
Here you can see what will happen to the cone and the aluminium toggles.
As you can see this stands in the centre of the amplifierbox. I also made a little carbon plate where it all is mounted on.
Through these holes, the amplifier-cabling will go.
For the moment, in the centre of the cone, there's a big blue led.
If this will remain, I'm not sure. I also have a white little neon that fits into there.
To divide the light a bit better, I milled a finer piece of plexi glass, and . This will come behind the JL Logo.
Here you can see the result with the blue led.
I think you can see that the cone is 10x more beautifully shaped. I call this is a female cone, a "conin"
You can also see I re-used the aluminum plate from the PPI. This was a bit to nice to throw into the bin, so it's being re-used.
The first cone I made, the one that landed directly into the garbage, I recovered.
I used this one to cover with carbon fire. I didn't had any problems with this.
About Evo2, I'm still not sure how to do this. It'll stay a mistery, and I'll have to do some magic. I hope there's something in my black hat...
  • Who's Online   0 Members, 0 Anonymous, 1492 Guests (See full list)
