Any of you old school PPI guys know anything about this one..Straight old School...It should power my 6.5's an 6x9's fine what you guys think,,?? If you find any specs for me post them please...
Edited by zaxfire69
Either that image is scaled WAY down, or I see some TINY power leads protruding from that thing! :o
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Yea those are the power leads..Ground and Power..I believe this amp is 4x25watts. I have been searching the net and can't find any info..This is an early 90's amp..Most companys back then did the leads like that.
Most likely it is 4x25 watts rms
Here is a apa430 and it is 4x30 watts.
http://ampguts.realmofexcursion.com/PPI_Sedona_APA_430iX/
so that may give you a lil more info.
EDIT: I just found this for ya. Maybe if there is a year on the amp this chart may help you out. I think its a pdf file but not sure.
http://www.phy6.net/downloads/PPI/General/PPI_Lineage.pdf
Good luck :)
Edited by audiofanaticz
That is what I was figuring..425 so..It should sound better than my stock radio anyway..Should be cleaner sounding. I see it was made in 1991..That is true old school..Jeez 16 yrs old..Now if I could just find the specs..Thank you for the help..
Edited by zaxfire69
I have a sedona apa100 2-ch.
looks just like your 425.
Cool amps.
So do you guys think I got a good deal for $60.00?? I think I did..This amp was rated at 12.4 volts..So it will put out quite a bit more than what it is rated.
Man I have to find a wiring diagram for this thing ..Ray do you have one or one that is close probably the same..??
  • Who's Online   0 Members, 0 Anonymous, 14127 Guests (See full list)
