ok, what would i need to run 4k rms? like alt wise and power wire? and i think i want a high idle output alt. so i dont know what the highest amperage those can put out are and if i would need an aftermarket batt.
200 amp+ alt+couple g31 batts would do it fine, i ran nearly 5k on 200 amp+3 batts all day long, 45 minutes to an hour straight no problems
1 15" LMS Ultra<-Sold
2 12" Audiopulse Axis Quad Coils
2 18" RD Audio Alpha V2's<--For Sale or Trade
American Bass VFL 700.1 (alot of power at any ohm)
American Bass VFL 200.1 (3.8k rms @ .5 ohm)
2.1 cubes each at 32 Hz
125 sq ft RAAMaudio BXT, 5 Yards Ensolite
50ft 1/0 Knu Flex wire
4 Infinity 6.5"
Temp 170x2@2 ohm Sony amp
200 Amp EA Alt
3 Exide Orbital's
Youtube Vids....http://www.youtube.com/profile?user=gavinriley&view=videos
i would like to stay away from extra batts if i could, i would like to run a stock batt with the necessary alt if possible? but im not sure if i will be able to do that. just wondering, to figure out what i need do i just add all the ampers from like all my car functions, with my head unit, and amplifiers?
if you get an absolutely monster alt then you could prolly keep it down to one extra battery so a 300amp alt + a kinteik 2400
if you really are looking for 4k rms and we'll say the amp is 80% efficient your electrical will need to be able to support 5000 watts (5000 * .80 = 4000)
please correct me if im wrong
so 300amp @ 13v = 3900 watts
a 2400 is 123ah so 123 * 13 = 1600
so with that you could support 5500 watts total
minus some because of course your car needs some of that power to run etc
and this doesnt figure in any mid/highs, just the 4k for your subs
this is just a rough outline, and again correct me if im wrong.
also there is plenty of videos under the hifonics section with mike styers doing some tuts about stuff like this.
hope this helps
P4killer.
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
1/0 power, and depending on your car, I might suggest keeping your stock alt and adding a second alt where your ac pump or something used to be.
A second battery would be a good idea
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
hope this helps
P4killer.
i dont want to have to redo your whole math but a car is gonna take up like 50-70 amps for actually running the car and other stuff.
ahh hell ill do it anyways. 240a*14v=3360w
123ah*14v=1722
*this is all assuming very little voltage drop, hence the 14v i used* equals all out to 5082w.
13v would equal out to 4719w
  • Who's Online   0 Members, 0 Anonymous, 2848 Guests (See full list)
