how in gods name is jacob only get 1ohm rise in his testing? im not calling him out, i want to know the secret. i just got a clamp meter and my impedance was 12.5! i have 2 saz-1500's strapped at 2.5ohm. tested at 45hz. gain set with an o-scope. my box is 5^ft, two 6" flared ports tuned to 39hz.
115.8volts/9.2amps = 12.5
115.8 x 115.8 = 13409.64/12.5 = 1072.77
obviously im very disapointed that my two 1500w amps are only doing a little over 500w each. so what can i do to lower my imp rise? im sure a new box would be in order but maybe there are some little things i can do to mine to help? im ready to improve my knowledge guys. teach me all you can. :friends:
i understand that but my peak is at 45hz so i only really cared about testing at that frequency. if there a way to lower the imp rise at 45hz? i mean, you only got less than 1ohm rise in your testing. there must be some way i can get results close to that.
ill go do more testing at some more frequencies
Edited by skittlesRgood
bigger box? thats a start.. wire to a lower resistance?
but damn 5x rise sucks.. most ive had is 4x rise
jus wire lower itll shrink down a lil
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
that would mean running them at .25ohm each. not really comfortable with that. not with only 2 batteries at least.
It won't be with box rise.... :spiteful: also I also noticed bigger port area =less rise
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
well if the theory behind flared ports being more efficient if true, i should have a lot of port area. maybe i need to go back to a slot port and go bigger?
With rise like that, something tells me you'd be alright running .25 ohms before rise. You'd probably have 1.5 or so ohms.
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
  • Who's Online   1 Member, 0 Anonymous, 1873 Guests (See full list)
