Posted (edited)
Don't use stailess steel Bolts, that is a horrible, horrible conductor....
Guys I live a a place where it rains 8 months out of the year,,, so water and corrosion is a problem. I like to use a product called "NO LOX",,, it is made by IDEAL, it helps prevent water and oxygen from getting into your connections and into the protective jacket.
Also going back to that solder discussion, it will be interesting if your imp, would drop with ont direct run..
more port area....
sorry about the .25ohm thing I thought you were burping...
Ideal's headquarters is in my town...
steel threaded rod w/brass nuts and washers had no change in resistance when able to measure .00 ohms
Edited by Decaf
but you have 3 6" ports for 4 12"s. i have 2 6" ports for 2 12"s. i dont know how big your box is but it looks like i have more port area per cube than you do.
it just sounds like im in that peak. i think next time ill tune lower so i can get to 45hz after that peak and still have good range for music.
I have 20% more box volume with 50% more port area in my quad 12" box.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
oh, its only 6 cubes? thought it was bigger.
alright, i have a few ideas to play around with this box for now. thanks for keeping up on this guys.
ok, i found out why my subs were reading 2.5ohm. with no resistance my DMM is reading .5ohm. im going to see if i can borrow some better meters from my dads work.
How much 8ga you need? :hi:
Ride - 2006 Scion xB
Equipment:
H.U. - Kenwood KDC-X793
Amps - Memphis 16-MC2.100
Memphis 16-MC1.1100
Front Stage - Memphis 15-MCC6 6.5 Components with silk dome tweets
Subs - Memphis 15-M310D4 10" Sub (x2)
Custom box 3.02 ft3 after displacement, tuned to 37 hz
Big 3
Second Skin Damplifier
Coming soon:
Kinetik HC1400
H.O. Alt
AudioControl three.1
so does this mean you dont have 5x rise you have 6x? wow that sucks
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
damn that's a lot of rise dude... let me know what takes place
will do.
i went out and got some JL 8awg but i need to take it back. its already green!! lol. but the good news is, i got a job.
lol, or it means i shouldnt trust my meters.
Just means youre really reading 2 ohm.. My meter reads .3 with the leads touching so when i measure my amp load it reads .8 instead of .5
lol yes, i am aware of that. but if its off by .5 im not sure how much i can trust the other readings as well. my cheap clamp meter is probably crap as well. once i get the good meters from my dad, i will retest and see if there is a difference.
  • Who's Online   0 Members, 0 Anonymous, 1121 Guests (See full list)
