I've always used a rairly decent ammount of wood glue durring construction, then after it's set-up, I would liquid nail all the seams, and press it into the seam with my finger...
2011 Dodge Durango Citadel AWD HEMI - LOADED
Stereo:  STOCK
Emergency Equipment:  Morotola - Federal Signal - Feniex - Gamber Johnson
Performance:  MOPAR Performance - Diablo
911 Calltaker / Diaptcher, Volunteer Ambulance Driver, Rescue Tech, Fire Fighter, Fire Policeman, Emergency Equipment Installer / Repairman
Titebond ftw
HU: JVC Arsenal AR880
Subs: (4) Incriminator Audio Warden 15s
Highs: (12)Eminator 8s (12)Eminator 6.5s (12)Eminence Apt80s
Amps: (2) Incriminator Audio 40.1s (subs), (2) MB Quart Discus 4125s, (1) MB Quart 4.80
Electrical:
-DB Electrical 275 amp Ohio Gen
-BIG III
-(5) XS Power d3100s
152.3 In Street Beat 5.
State record in Alabama. (USACI)
http://www.youtube.com/Itgetslow
Eh not exactly I went through almost 2 bottles of titebond II and it definitley holds the wood together but its not viscous enough to qualify as a sealant. I have also tried liquid nails, but its too malleable when it cures.
Also a bit OT here but while I have this thread up, does anyone know the best way to clean off woofers surrounds? My 18s got a bit dusty during construction and I don't to damage the foam surrounds with chemicals.
Adhesive automotive silicone for the box corners and good 'ol WD-40 for your surround
I resin and fiberglass the seams of my boxes.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
Great idea with the wd-40, Ill give that a shot. Also I do smooth the liquid nails, I guess I just haven't given it enough time to cure.
Yes, and probably... LoL
Stereo:  STOCK
Titebond and then any silicone based sealed works just fine 99.9% of the time, just use your fingers to push it into the corners. After that you can 45 the corners where the major airflow will take place, then glass and resin over that. I know u said no glass or resin but it really is the best option.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 585 Guests (See full list)
