what are some ideas for holding my box in place in my trunk besides drilling through the trunk and into the box?
2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012drew.png
no. this is for converting dc to ac. useful if you want to run a blender inside your car.
Lots and Lots of velcroe... like, the whole underside of your box! And make sure you get an industrial strength with large hooks, not the flimsy stuff
Ride - 2006 Scion xB
Equipment:
H.U. - Kenwood KDC-X793
Amps - Memphis 16-MC2.100
Memphis 16-MC1.1100
Front Stage - Memphis 15-MCC6 6.5 Components with silk dome tweets
Subs - Memphis 15-M310D4 10" Sub (x2)
Custom box 3.02 ft3 after displacement, tuned to 37 hz
Big 3
Second Skin Damplifier
Coming soon:
Kinetik HC1400
H.O. Alt
AudioControl three.1
You could attach right-angle metal tabs on the bottom corners of your box, have threaded bolts coming up through the floor, and secure the tabs to the bolts with nuts. Just a suggestion.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
i like the idea, but i dont want to drill through the body if i dont have to
velcro
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
we had this problem in my buddys car, he has easy replace headlights and all that at the rear bumper and so we just got some old angle iron i had laying around with bunch of wholes already drilled into it unscrewed the nuts placed the angle iron over screwed them back in (did for both sides) and used a ratchet strap and she holds tight
R.I.P!
(Nov-29-2009)
92 explorer
current build
I've always used med-large L clamps but you said u didn't want to drill into the box or body. You could use the ratchet straps as mentioned and they work pretty well, but they are very visable. I also knew someone who built a false floor and actually glued the underside of the enclosure to the false floor. It worked great and after it was all carpeted you couldn't tell that it was done. But obvious downside is that you can't move the enclosure without having to tear it out and start from scratch for the most part.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 1021 Guests (See full list)
