Marlo Stanfield Posted November 21, 2009 Report Share Posted November 21, 2009 That is exactly what I had in mind. I don't plan on running these babies at .5 ohms. I just wanted to know if they could be ran that low. Honestly if someone wanted to I would like to also know what is the big deal about .5 ohms. I just don't get it. And again I am having professionals install my stuff and I will be right there learning, but I at least need the right materials. Hell I wouldn't need 6000 watts ran to any of my BTL's I just like the possibility of the amps. So I would most likely be running a 14v system or 16 v system. Just so u won't be getting flamed by sum of people on here it's not actually a 14v system.. It's a 12v system but usually charges over 14v, so it's referred to as a 12v system. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
OldsBoomer Posted November 21, 2009 Report Share Posted November 21, 2009 Nofearx18 on here is using these amps at his shop currently... a customer came in wanting to be extremely loud and they ar putting 4 18" mayhems and 4 AQ 3500's into a hummer.. Dual alt setup and multiple batteries obviously. But eventually im going to picking one of these because the owner of the shop talked to the guys at AQ and from what i was told they are redesigning the AQ 3500 and when they do it'll 4300 rms at 14.4(this is what they were told). So ill wait for that and at 16 volts it'll be 5K i think it was.. and yes they are able to do .5 ohms daily Nofearx18 ran his daily at .5 ohms and to your ? about why its harder to run a amp .5 ohms... ok as i understand it with the less resistance that the amp has the current it'll draw and it wont be as efficent and will produce more power and also more heat. More heat on the board and heat sink will increase your risk of blowing your amp. so as stated before just run your amp and its rated ohm load of 1 ohm and keep your amp safer and as efficent as you can with as much power that you can get. And going above a 12 volt system for daily isn't always the best unless you know what your doing because you'll be pushing your amp harder then designed but it's more then possible i suggest following the advise given so far. Please if any of this info is incorrect please correct me Suburban Coming Soon Link to comment Share on other sites More sharing options...
Red-navi-916 Posted November 21, 2009 Report Share Posted November 21, 2009 i believe bigg boy on here has 6 BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass. Link to comment Share on other sites More sharing options...
brewer_brewer Posted November 21, 2009 Report Share Posted November 21, 2009 sorry to the OP on this one getting way off topic. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
steven Posted November 21, 2009 Author Report Share Posted November 21, 2009 sorry to the OP on this one getting way off topic. No worries. The more people post the more I get to laugh at the questions and to the guy running 4 btls DONT DO IT. Its a lot harder than your expecting it to be... I hope your ready to spend around 2 grand on JUST your electrical. Link to comment Share on other sites More sharing options...
tripleb45 Posted November 21, 2009 Report Share Posted November 21, 2009 No worries. The more people post the more I get to laugh at the questions and to the guy running 4 btls DONT DO IT. Its a lot harder than your expecting it to be... I hope your ready to spend around 2 grand on JUST your electrical. Well I plan on doing about 3 grand so I would be happy at 2 grand and could put money aside lol. Link to comment Share on other sites More sharing options...
steven Posted November 21, 2009 Author Report Share Posted November 21, 2009 Nofearx18 on here is using these amps at his shop currently... a customer came in wanting to be extremely loud and they ar putting 4 18" mayhems and 4 AQ 3500's into a hummer.. Dual alt setup and multiple batteries obviously. But eventually im going to picking one of these because the owner of the shop talked to the guys at AQ and from what i was told they are redesigning the AQ 3500 and when they do it'll 4300 rms at 14.4(this is what they were told). So ill wait for that and at 16 volts it'll be 5K i think it was.. and yes they are able to do .5 ohms daily Nofearx18 ran his daily at .5 ohms and to your ? about why its harder to run a amp .5 ohms... ok as i understand it with the less resistance that the amp has the current it'll draw and it wont be as efficent and will produce more power and also more heat. More heat on the board and heat sink will increase your risk of blowing your amp. so as stated before just run your amp and its rated ohm load of 1 ohm and keep your amp safer and as efficent as you can with as much power that you can get. And going above a 12 volt system for daily isn't always the best unless you know what your doing because you'll be pushing your amp harder then designed but it's more then possible i suggest following the advise given so far. Please if any of this info is incorrect please correct me I was not sure if this was directed at me, but anyway; Yes your correct and thats just 1 reason I wouldnt suggest running the amp at .5 ohm. I know I know a ton of people do it and it works fine but in a NORMAL situation its just too taxing on the amp and Im not willing to thrash on $600 that easy and 1 more thing to the guy with 4-6 btls read this thread I posted http://www.soundsolutionsaudio.com/forum/i...on-wiring-btls/ Words on wiring the btls at .5 ohm from the man him self... Link to comment Share on other sites More sharing options...
DJL Posted November 21, 2009 Report Share Posted November 21, 2009 Nofearx18 on here is using these amps at his shop currently... a customer came in wanting to be extremely loud and they ar putting 4 18" mayhems and 4 AQ 3500's into a hummer.. Dual alt setup and multiple batteries obviously. But eventually im going to picking one of these because the owner of the shop talked to the guys at AQ and from what i was told they are redesigning the AQ 3500 and when they do it'll 4300 rms at 14.4(this is what they were told). So ill wait for that and at 16 volts it'll be 5K i think it was.. and yes they are able to do .5 ohms daily Nofearx18 ran his daily at .5 ohms and to your ? about why its harder to run a amp .5 ohms... ok as i understand it with the less resistance that the amp has the current it'll draw and it wont be as efficent and will produce more power and also more heat. More heat on the board and heat sink will increase your risk of blowing your amp. so as stated before just run your amp and its rated ohm load of 1 ohm and keep your amp safer and as efficent as you can with as much power that you can get. And going above a 12 volt system for daily isn't always the best unless you know what your doing because you'll be pushing your amp harder then designed but it's more then possible i suggest following the advise given so far. Please if any of this info is incorrect please correct me The new AQ3500D.1 will be rated at: 1400@[email protected] 2600@[email protected] 4300@[email protected] 5300@1ohm@16V 6000@1ohm@18V Above are @ less then 1%thd 7000@1ohm@6%thd 8600@2ohm [email protected] less then 1%thd 10,600@2ohm strapped@16 " " " 12,000@2ohm " '' @18 " " " 14,000@2ohm " " @18@6% thd Working voltage 9.5-18.5 Tested voltage @14.4@less then 1%thd based on CEA(2006) 2x0 gage connections Link to comment Share on other sites More sharing options...
greg662 Posted November 21, 2009 Report Share Posted November 21, 2009 The new AQ3500D.1 will be rated at:1400@[email protected] 2600@[email protected] 4300@[email protected] 5300@1ohm@16V 6000@1ohm@18V Above are @ less then 1%thd 7000@1ohm@6%thd 8600@2ohm [email protected] less then 1%thd 10,600@2ohm strapped@16 " " " 12,000@2ohm " '' @18 " " " 14,000@2ohm " " @18@6% thd Working voltage 9.5-18.5 Tested voltage @14.4@less then 1%thd based on CEA(2006) 2x0 gage connections when do these come out? 2 15" DC LVL 5' crescendo 5500 yellow top under the hood and two xs power d3100 Big three upgrade Rockford Fosgate T162S components in front Rockford Fosgate T152 in the back Dynamat everywhere Link to comment Share on other sites More sharing options...
DJL Posted November 21, 2009 Report Share Posted November 21, 2009 when do these come out? Scheduled for end of December but probably 2nd week of Jan is more realistic. Link to comment Share on other sites More sharing options...
