ACTIVE CROSSOVERS
MrSoundz
How many of you use active crossovers in your system? Instead of using the head units or amplifier's crossovers, you have external crossovers do the job for you. I am considering adding one on my system.
dont you mean passive? active is when you use amplifiers/HU's for crossovers, passive is when you use an external crossover
that, or i dont get what your saying?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Oops, I meant to say passive.
thought so, lol
but yeah, im running passive crossovers, only because they came with my components and pheonix gold RSD6cs arent worth running active, id only run active with a very prestigious type of components, ones that are MEANT to be ran active, high ends like focals, rainbow, hybrid etc and so on.. thats what i think at least.
Team Sundown Audio
you sir a wrong and right. Active simply means it is crossed over before amplification, passive is after. So an externam xover, that intercepts the RCAs signal before amplification is still active. Im actually looking into what xover to run to go active in my next setup
I have used an active crossover in a buddies system (bass x-over), it was a VERY basic one at that. Had a few slope options to select from and boost options, but in the end it gave his subs a well needed tuning since his H/U did not have any x-over features what so ever.
Depending on what you're going for, if you get a decent headunit they can do a damn good job at giving you MANY of fine tuning settings.
For instance my alpine 9887 has a very nice built in X-over that is fully user tunable. I believe eclipse has an even more flexible one out now.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
i use a audiocontrol 4xs
DC.jpgDC POWER
thought so, lol
Actually you're PG's do need to be ran through an active crossover as well. All speakers kinda work the same, and if you know what frequencies are safe for them they will sound like they should. From the looks of it you are running them off of an amp, that's where you want to limit what those components are getting. Although they still have the passive crossover block, that is made to separate the frequencies and direct them to either the mid driver, or the tweeter. I'm pretty sure that specific set does not allow a HPF for the mid driver. So in that case you will be getting VERY low bass notes to your mid driver. Not a good thing.
I'm looking at adding those exact components into my truck doors, they will be ran externally from an amp, however I will limit the HPF directly from the alpine. If you notice on the specifications of those components, the frequency range is suggested at 45hz and up. So giving that little 6.5" mid driver a note below 45hz would probably damage the driver over time. I'd set the HPF at about 70hz or even higher with a pretty long slope, but that's just me.
Proud DC owner
