i was considering buyin a rockford fosgate 1/0 awg amp wiring kit but came across a cheaper price on a STINGER 0 gauge wire.
I was wondering if the stinger brand had some legit quality to its wires?
Has anybody tried the stinger wires and is there any difference in brand when it comes to wires??/
Like do some brands try to cheat you with less wire in the rubber insulation?
Or is the matieral used in the wires different with price?
Or do some wires just work better than others??
PLEASE HELP IM IN URGENT HELP!
Yes they do, Stinger Pro is sum very good wire.
Yes, some wiring is better or worse than others. This is due to strand count, what type of wire it actually is, and for install purposes flexibility of the wire.
Yes they make a thicker jacket with a smaller strand count to make the wire appear larger than it seems. Outside might be the same size of a regular 1/0 wire, the actual wire inside could be 2ga or 4ga in some cases
CCA(copper clad aluminum) is cheaper than oxygen free copper wire, because copper is more expensive. Copper is also a better conductor of electricity than aluminum is, so the pure copper wire is better quality vs. the same size/strand count wire that is CCA
Already answer that for ya in the previous questions
There ya go man, hopefully that helps out. Best 1/0 wiring kits out there IMO are the Kicker Hyperflex kit and this one from Knukonceptz - http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0
Pioneer AVIC-N2
I'd say knukonceptz or find someone on here selling wire(scottiej, --navi--) those are the only two that I know so far
I know if I ever find out you were messing with my 17yr old daughter, i'm diggin' off in that ass and then your next post will be asking for tips on how to remove my size 12 shoes from your ass.
Open Up The Trunk
Pioneer P6000Ub H.U.
Sundown Saz-1500D
Hifonics ZXi 4410
12" Directed SX12D4 (x2)
12" 1500rms Sub x1
Front - Powerbass 4XL-65-92 Mids
Rear - Cadence 6.5" Mids
Electrical Under Construction
Check Me Out(CarAudio Vids)
Official Feedback Thread
Check Out My Music Page
x2 on the PKD1 kit.
Vehicle: 2001 Dodge Dakota
Headunit: Alpine IVA-D310
Sub: 2005 RE Audio XXX 15"
Sub Amp: Orion 2500D
Frontstage: Diamond Audio Hex's
Frontstage Amp: Sundown Audio SAX-100.4D
Wiring: Kicker Hyperflex 1/0
Alternator: Mechman 250 Amp
Battery: Powermaster D2700
Deadener: 100 Square Feet Raamat BXT II
If you truely want the best then audison sonus is where its at. If the cost to much for you though then the kicker kit i like
kicker pkd1. i have some stinger HPM 1/0 and its junk compared to kicker
DC.jpgDC POWER
  • Who's Online   0 Members, 0 Anonymous, 764 Guests (See full list)
