tripleb45 Posted December 3, 2009 Report Posted December 3, 2009 In a strange turn of events I am stuck with a 18" Fi BTL newer style sub that is "fully loaded" and "D2". This is the problem How can I fix it. The tech said it looked and felt like it was going to fall off and I agree it looked like a strong wind would knock it over, but I need this fixed or is a recone the only way. For some reason this affects the sound and makes it play at normal volume and then nothing. Please help like I said we know what happened, but I don't want any drama just a solution. This is what it should look like: Please help. No bashing. Quote
AI James Posted December 3, 2009 Report Posted December 3, 2009 are they snapped under the glue or are they still together just the nasty glue on them? honestly id just buy new terminals and replace them. Quote
FI50 Posted December 3, 2009 Report Posted December 3, 2009 I think that if you just take all the goop off and re-soder the terminals you should be fine. Good luck man thats a nice sub. Quote 04 v8 explorer with a fully loaded 15" BL
uhoh_45 Posted December 3, 2009 Report Posted December 3, 2009 I think that if you just take all the goop off and re-soder the terminals you should be fine. Good luck man thats a nice sub. x2 do that clean glue off and re solder Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
tripleb45 Posted December 3, 2009 Author Report Posted December 3, 2009 are they snapped under the glue or are they still together just the nasty glue on them?honestly id just buy new terminals and replace them. The whole thing wiggles and this glue is fukin sloppy. I will attempt to do that. I think that if you just take all the goop off and re-soder the terminals you should be fine. Good luck man thats a nice sub. Thanks man I think the sub has been disrespected by this sloppy work. x2 do that clean glue off and re solder will attempt maybe tomorrow. Quote
thehoe92 Posted December 3, 2009 Report Posted December 3, 2009 PM foreverbumpn dudes a wiz at this type of shit he probably has some terminals for you too Quote Wouldnt be thehoe92 without teh purple
tripleb45 Posted December 3, 2009 Author Report Posted December 3, 2009 (edited) thanks man. I feel like posting " his" last message to me, but I will keep it clean. Edited December 3, 2009 by tripleb45 Quote
Shyne151 Posted December 3, 2009 Report Posted December 3, 2009 Truthfully it's an easy fix if you can get the glue off... just resolder the lead back on, same thing you would do if you did a recone. Quote -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
tristan560 Posted December 3, 2009 Report Posted December 3, 2009 Lookin to start shit again. But honestly...havent talked to "him" Im over this...i can help you out if you wanna pm me about it. I broke the one on my ssd 15 and had to re-do it. Let me know. Its not a hard fix. Quote <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
tristan560 Posted December 3, 2009 Report Posted December 3, 2009 the lead is fully intact...the bolt stripped thru the plastic on the terminal. Quote <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
