In a strange turn of events I am stuck with a 18" Fi BTL newer style sub that is "fully loaded" and "D2". This is the problem
How can I fix it. The tech said it looked and felt like it was going to fall off and I agree it looked like a strong wind would knock it over, but I need this fixed or is a recone the only way. For some reason this affects the sound and makes it play at normal volume and then nothing. Please help like I said we know what happened, but I don't want any drama just a solution. This is what it should look like:
Please help. No bashing.
are they snapped under the glue or are they still together just the nasty glue on them?
honestly id just buy new terminals and replace them.
I think that if you just take all the goop off and re-soder the terminals you should be fine. Good luck man thats a nice sub.
04 v8 explorer with a fully loaded 15" BL :)
x2 do that clean glue off and re solder
R.I.P!
(Nov-29-2009)
92 explorer
current build
The whole thing wiggles and this glue is fukin sloppy. I will attempt to do that.
Thanks man I think the sub has been disrespected by this sloppy work.
will attempt maybe tomorrow.
Truthfully it's an easy fix if you can get the glue off... just resolder the lead back on, same thing you would do if you did a recone.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
Lookin to start shit again. But honestly...havent talked to "him" Im over this...i can help you out if you wanna pm me about it. I broke the one on my ssd 15 and had to re-do it. Let me know. Its not a hard fix.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
