I have a 99 Pontiac Bonneville, my doors have 1 4" speaker and 1 tweeter in each door.
Im lookin to upgrade from 4s to 5.25s or 6.5s.
Will I have enough depth to fit these or will I have to make an adapter to fit it?
Help appreciated, thanks.
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
most likely youll need an adpater if for no other reason but for mounting to the surface itself. depth just measure accordingly
Alright sounds good. I figured thats what I would need to do.
I just hope itll fit without havin to fab up somethin too much for my doors.
For sure. I actually plan on doing a build log soon.
I'll have to throw these in there once I start.
Any tips on making some rings for the speakers?
my 98 bonne came with 5.25s mounted from the rear side of the door panel.i made a temp pod to hold 6.5s but plan to do some glass work on my doors next year.you have the depth and migght be able to find dif door panels at a salvage yard that came with the bigger openings if your not wanting to mod yours at all
Hey, cracker! Nice to see you here.
I was able to fit 6.5" speakers in the stock mounting location. I used vacuum tubing as standoffs so that the cone wouldn't hit the smaller hole, and then I used the mounting holes that were on the speaker for a 3-point mount. When speakers can be mounted onto a car using 3 points, they get the bottom two, top hole, and then the first two holes along the top and the top hole also at the bottom. This gives you a 4-point mounting setup that lines up perfectly with a 5.25" speaker's mount.
Well it seems that every website I go to says something different.
Anyone know a reliable site to figure out what size I do have?
