Quick Question, Need Quick Response Please
Ok i know that there are probably a hundred posts about a second battery. I tried searching but the search wasnt working. Ok so my grandpa bought me a second battery for my car for my system. He wants to pay for everything that i need to wire it up in the trunk as a second battery. I am trying to finds the cheapest way to do so. MY question:
Can I run a wire from the front battery's positive terminal to the back battery's positive terminal and then ground the back battery's negative terminal to the chassis? im trying to avoid two runs of 0 gauge because it is expensive and im trying to save gramps some money. Im going to get the KnuKoncepts 1/0 cable and im going to do Big 3 under the hood.
Do I need to but a fuse in the cable between the two batteries?
Any help is greatly appreciated. He wants to get it ordered today or tomorrow btw.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
Yes and Yes.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
I wouldn't have any power wire in my vehicle that runs the length of the car without a fuse on it. And you can ground to the frame, though a direct connection would be better.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
run a fuse in between your two batteries (positive to positive) and run a fuse between your battery and your amp so you'll want 2 fuses
Current Setup (pictures/videos uploaded)
1997 Grand Prix Se 3.8 V6 (220HP stock)
105A Alternator
Big III
5/8 Gauge Wiring
1 x Alpine MRP-450.1 (1x450RMS @ 2OHM)
1 x Alpine MRP-500.2 (2x250RMS @ 4OHM)
2 x 6 1/2 Infinity Reference 3-WAY (250RMS)
2 x 6 by 9 Infinity Reference 3-WAY (300RMS)
1 x Pioneer dEH-11
1 x 3.5cu .75MDF tuned @ 33hz (VENTED)
2 x Kicker COMP 15" S4
Coming Soon! (pictures/videos included)
1997 Grand Prix SE with rear seat removed
225A Iraggi Alternator
Big III
Rear Deep Cycle
0/1 Gauge Wiring
1 x Alpine MRP-500
1 x Alpine MRP-450
1 x Alpine CDA-9885 60x4 RMS
1 x Hifonics Brutus 1605D (1600RMS x 1 @ 1 OHM)
2 x Fi SSD 15" Copper Coil D1
1 x 5.5cu .75MDF tuned @ 33hz (VENTED)
Should the fuse be at the engine end or the trunk end? I am goin to chop off the current wiring kits i have and use the fuses out of them for the amps.
id do both since either end will be "hot". its better to be safe than sorry.
Ok thanks for the info guys.
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
