Hey, I am wondering how you calculate and tune for differnt hertz, when building a box. I know hertz is cycles per second, but what is the difference in higher hertz and lower hertz. i see alot of people tune there boxes to like middle 30s. I am just wanting a basic understanding of what different hertz do and how you create different hertz when building a box...thanks alot.
R.I.P!
(Nov-29-2009)
92 explorer
current build
In a ported enclosure you can tune for specific hz by adjusting the length of the port... In every different sized enclosure the length will differ for whatever you are trying to tune to.
Pioneer AVIC-N2
port area also plays a role. the more port area you have, the longer the port needs to be to maintain a frequency tuning of a port that has less port area. the port with less area can be much shorter. also you dont want too much port area or too little port area. general rule of thumb is 12-16 sq inches of port per cubic foot
ok, so how to i calculate port area.
*sigh*
for a square its height * width
for a circle its pi*r^2
8th grade geometry
i likes me some audio stuff...
wow im a highschooler and just learning the important stuff about car audio. You guys started somewhere too. But thanks for the help.
trial and error bud (not trying be a dick) but i learned on my own after failing i picked up a pen and paper and calculator and started reading
plug in your numbers in the http://www.the12volt.com/caraudio/boxcalcs.asp figure out how many cubes your box is.
box = X = 5 cubes
so in order to find my port area i times how many cubes my box is by 13-16 to find out how many square^2 of port there is
so 5*15 is 75 so i'd have 75^2 of port
once i have that need to plug in some numbers to make that 75" of port work with you so say my port is 12" tall i need it to be 6.25" wide
i get all that and take it here and plug in my numbers and come up with how long my port needs to be
pretty simple
R.I.P!
(Nov-29-2009)
92 explorer
current build
