Try checking over one more time you might have a crossed wire you might have over looked.
VehicleCurrentlyOwned:2000Malibu
\/MySystem\/
Ken-Wood HeadUnit
Cars interior panels Custom blue Done by ME
Pheonix Power block running both amps
Stinger pro series four gauge wire flex material
RimsBrand:Polo
Interior lighting Blue neon bars under and around dash
Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED)
http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg
http://www.dcsoundlab.com/images/header.jpg
That battery is small but I dont see that causing your problem.
I would check voltage at the alt, batt, and amp and compare them all under the same load. That will get you started.
Iraggi
Will do. Ill post up my results later.
Thanks.
04 Armada. Lifted 35" Toyo MTs.
Sundown 1200saz
Fi Bl Fully Loaded
I am interested in your answers.
I need to kno what's happening.
you seem to have a good electrical system, with bad results.
I have the same results with a stock electrical system (that I want to improve) !!!
Waiting for informations !
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Yes at the moment it is my only battery and all my power/ground wires are 1/0. Also my gain setting is a little under 3/4.
I have a ground going from the battery and from the alternator. So 2 total. Also I have the additional factory ground and a 1/0 ground from the frame to the engine. How would I check the wiring for voltage drop?
Rob ill be pm'ing you in just a second. Thanks for the reply!!!
maybe its just me but i dont think youre supposed to ground your alternator, just from the battery and from the engine block.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Another battery would help buffer out those voltage dips.
Yeah I definetly will let you know. And hopefully it will help out a lot of people. I messed around with some things yesterday but I didn't have time to test the voltage drop around different points. At this point I still have no clue what it is so...
Oh and dugee81 I was told that it would just help to have another run of ground so I did it to see if it would fix my problem. (did not help)
I am hopping tomorrow I can get some time to work on things and hopefully figure this thing out.
Sundown 1200saz
Fi Bl Fully Loaded
I've had weird voltage stuff with that truck stock..lol
added a overhead screen and saw some funky stuff
Your headlights are just gonna dim bro.
either do hid, or put a 1/4farad cap on the headlight feed wires.
Alot of newer cars need this.
BMW, Nissain etc
Your charging voltage seems low for having a high output alt. Correct me if Im wrong but shouldnt most cars charge around 14.4 or 14.5.
Did you go to a larger alt pulley when you changed alts?
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
  • Who's Online   0 Members, 0 Anonymous, 614 Guests (See full list)
