Rydaz1Bass Posted December 12, 2009 Report Share Posted December 12, 2009 Try checking over one more time you might have a crossed wire you might have over looked. Quote VehicleCurrentlyOwned:2000Malibu \/MySystem\/ Ken-Wood HeadUnit Cars interior panels Custom blue Done by ME Pheonix Power block running both amps Stinger pro series four gauge wire flex material RimsBrand:Polo Interior lighting Blue neon bars under and around dash Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED) http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg http://www.dcsoundlab.com/images/header.jpg Link to comment Share on other sites More sharing options...
Iraggi Alternator Posted December 12, 2009 Report Share Posted December 12, 2009 That battery is small but I dont see that causing your problem. I would check voltage at the alt, batt, and amp and compare them all under the same load. That will get you started. Iraggi Quote Link to comment Share on other sites More sharing options...
yota_oddball Posted December 12, 2009 Author Report Share Posted December 12, 2009 That battery is small but I dont see that causing your problem.I would check voltage at the alt, batt, and amp and compare them all under the same load. That will get you started. Iraggi Will do. Ill post up my results later. Thanks. Quote 04 Armada. Lifted 35" Toyo MTs. Sundown 1200saz Fi Bl Fully Loaded Link to comment Share on other sites More sharing options...
notorious97200 Posted December 15, 2009 Report Share Posted December 15, 2009 I am interested in your answers. I need to kno what's happening. you seem to have a good electrical system, with bad results. I have the same results with a stock electrical system (that I want to improve) !!! Waiting for informations ! Quote black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a 2.6 ft3 ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area. Link to comment Share on other sites More sharing options...
BulletInjection Posted December 15, 2009 Report Share Posted December 15, 2009 im running 2600 watts and your battery is larger than mine but at 1500 rpm even on the heaviest hitting songs / tones I only drop .3 so it sure isn't the battery... if ya think so ill trade Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
dugee81 Posted December 15, 2009 Report Share Posted December 15, 2009 Yes at the moment it is my only battery and all my power/ground wires are 1/0. Also my gain setting is a little under 3/4.I have a ground going from the battery and from the alternator. So 2 total. Also I have the additional factory ground and a 1/0 ground from the frame to the engine. How would I check the wiring for voltage drop? Rob ill be pm'ing you in just a second. Thanks for the reply!!! maybe its just me but i dont think youre supposed to ground your alternator, just from the battery and from the engine block. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
MECHMAN Posted December 15, 2009 Report Share Posted December 15, 2009 maybe its just me but i dont think youre supposed to ground your alternator, just from the battery and from the engine block. Another battery would help buffer out those voltage dips. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
yota_oddball Posted December 16, 2009 Author Report Share Posted December 16, 2009 I am interested in your answers.I need to kno what's happening. you seem to have a good electrical system, with bad results. I have the same results with a stock electrical system (that I want to improve) !!! Waiting for informations ! Yeah I definetly will let you know. And hopefully it will help out a lot of people. I messed around with some things yesterday but I didn't have time to test the voltage drop around different points. At this point I still have no clue what it is so... Oh and dugee81 I was told that it would just help to have another run of ground so I did it to see if it would fix my problem. (did not help) I am hopping tomorrow I can get some time to work on things and hopefully figure this thing out. Quote 04 Armada. Lifted 35" Toyo MTs. Sundown 1200saz Fi Bl Fully Loaded Link to comment Share on other sites More sharing options...
Ray Posted December 16, 2009 Report Share Posted December 16, 2009 I've had weird voltage stuff with that truck stock..lol added a overhead screen and saw some funky stuff Your headlights are just gonna dim bro. either do hid, or put a 1/4farad cap on the headlight feed wires. Alot of newer cars need this. BMW, Nissain etc Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
TheSundownFire Posted December 17, 2009 Report Share Posted December 17, 2009 Your charging voltage seems low for having a high output alt. Correct me if Im wrong but shouldnt most cars charge around 14.4 or 14.5. Did you go to a larger alt pulley when you changed alts? Quote 1999 Pontiac Sunfire Alpine CDA-9886 Sundown Audio SAZ-1000D Sundown Audio SAX-50.4 Rainbow SAC 265.25 Components Image Dynamics iD12 Optima Yellow Top SQFire FTW. Link to comment Share on other sites More sharing options...
