HC3400BLK Posted May 19, 2007 Report Posted May 19, 2007 which is better dual 2 ohm r dual 4 ohm kicker cvx 2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
Bryan Posted May 19, 2007 Report Posted May 19, 2007 isnt the rms 1k? if so 4ohm imo.. cause more amps put out 1k at 2ohm than 1ohm i think...if im correct MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST 2 AudioQue HDC3 18'' subs Rockford Fosgate T1 6.5 mids MMATS 2000.05 XS Power D1200 Knukonceptz 1/0 Pioneer Premier DEH-P490iB " Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
Amalan Posted May 19, 2007 Report Posted May 19, 2007 depends on alot of things. if you get 2 and your amp is only down to 1 ohm stable then 2 4ohm cvx can be wired to 1ohm to give them the most power. if your amp is only 2ohm stable then 2 2ohm would be best if you only want to do 1 then 2ohm would be the best but if you plan on getting 2 in the future then 4 would be best unless you can find an amp that will be stable at .5 ohm but a single 2ohm sub can be wired down to 1ohm and a 4ohm sub can be wired to 2ohm so if your amp is 1ohm stable go with 2ohm if my explanation is confusing then go to the rockfordfosgate website then support then woofer wiring wizard and you can check it out.
Derrick824 Posted May 19, 2007 Report Posted May 19, 2007 Basically it all depends on what amp you're going to use. Make sure and get the correct coil configuration to get the most power out of your amp.
HC3400BLK Posted May 19, 2007 Author Report Posted May 19, 2007 im goin 2 buy 2 of them. the amps i was lookin at is these:(the number by the link indicates how many) http://cgi.ebay.com/POWER-ACOUSTIK-2100-WA...1QQcmdZViewItem (1) http://cgi.ebay.com/MA-AUDIO-HK1000D-1000-...1QQcmdZViewItem (1) http://cgi.ebay.com/2000-WATT-MONSTER-POWE...1QQcmdZViewItem (1) http://cgi.ebay.com/MA-AUDIO-HK1998-1200-W...1QQcmdZViewItem (2) 2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
Coolwazabi Posted May 22, 2007 Report Posted May 22, 2007 get 2 kicker CVX dual 4 ohms.. and get that PA amp..
Slinky Posted May 22, 2007 Report Posted May 22, 2007 x2, 2 dual 4 ohm cvx and a pa a3000db would be good. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
