Which Is Better
isnt the rms 1k? if so 4ohm imo.. cause more amps put out 1k at 2ohm than 1ohm i think...if im correct
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
depends on alot of things. if you get 2 and your amp is only down to 1 ohm stable then 2 4ohm cvx can be wired to 1ohm to give them the most power. if your amp is only 2ohm stable then 2 2ohm would be best
if you only want to do 1 then 2ohm would be the best but if you plan on getting 2 in the future then 4 would be best unless you can find an amp that will be stable at .5 ohm
but a single 2ohm sub can be wired down to 1ohm and a 4ohm sub can be wired to 2ohm so if your amp is 1ohm stable go with 2ohm
if my explanation is confusing then go to the rockfordfosgate website then support then woofer wiring wizard and you can check it out.
rims.jpg2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
x2, 2 dual 4 ohm cvx and a pa a3000db would be good.
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
  • Who's Online   0 Members, 0 Anonymous, 1220 Guests (See full list)
