Bravada Zapco Install In Progress
Well, this is my first car audio install I've ever done and I've been working on this for a while off and on, but now am getting close to finishing.
I'm not sure what I did with the pics I took early on, but here it is.
These three pics were one idea, but I decided it was way to much for now
Here are the now photos
everything is run from a carputer
I might start wiring the rest over Christmas if the family gives me the time
Tell me what you think Thanks
I'll throw up a few more pics here.
first is the rack slid all the way out the back.
Here are a few closeups of the slides I made. foe each slide, the main base piece is 2 pc of 2" x 2" x 1/8" angle with a strip of 1/8" flat stock in the middle. I then stitch welded them together. the second and third pieces are 1 pc 2" x 2" x 1/8" angle with a strip of 1/8" flat stock. I then stitch welded them together also. then through them in the Bridgeport, and spent about 3 1/2 hrs milling the slots in the upper and lower brackets. I milled them to .575" for what I thought would make them slide easier, but if I doo it ever again, I'll make or buy linear slides, and maybe air actuate it. next I through all the pieces in the surface grinder to flatten the mating sliding surfaces. I got to about .0007" flatness, could have done .0001", but would take many more passes, and what the hell, there slides I drilled in some .497 holes in the center section for a press fit of the hardened shoulder bolts , and then mungo welded them in. they are bolted all the way through the floor pan with 6pc of 1/2" carriage bolts with backers. they work good, but I should have checked the alignment on the Bridgeport cause the slots were off by .009" end to end, so when I slide it out the weight of the rack cocks it to one side a little. oh well still first time trying all this.
I'll post more close-ups of the other welding projects later. long ass day at work.
I've got this posted on the Zapco web site also.
Carputer, 2GB Memory, 2x 64GB SSD's, DVD, Wifi, Bluetooth, Remote Control.
Rockford Fosgate EPX2 Symmetry, With DSP Card
Zapco 650.6 4 Ch-Tweets, 2-Ch for PG Cyclone
Zapco 1000.4 - Mids
Zapco 4kw - subs
Right now, All RF Speakers
10" Military Touch Screen
5 Optima Batts
250 Amp Alt with external MOSFET regulator I built for it
4 Inch Lift
31" Mud Terrain Tires
And Still Working On It.
More To Come.......
Damn thats alota stuff in there!! Gana be a hell of a first build
2000 GMC sierra 1500 ext cab
KMC XD Spy series rims
Front doors Fosgate punch 6 1/2's stock tweets
Rear doors Fosgate power 4x6's
Probox 10 and box under rear seat
Rockford fosgate R-500 Prime series amp (537 rms)
4 gauge wiring
You should be a little more ambitious for your first build or you'll never get anywhere.... :lol:
Thanks, after seeing all the krazy stuff people build here, I think I have a ways to go.
thanks all for the other comments. when I get home after work in a while I'll post some more pics.
Thanks.
Zapco 1000.4 - Mids
Zapco 4kw - subs
5 Optima Batts
4 Inch Lift
More To Come.......
