Ok I have been searching for a while now and I can't find what I am looking for. I am looking to get an idea on running 3 big amps at .5 ohms in my build. I only have a few names, but no prices and my internet is acting stupid and slow right now so my search engines on here suck. I have a few ideas of who I have in mind but these are not concrete if you have any other ideas and prices please post them.
Ok these are the brands I have so far the 8000 watt versions of course
DAT 8.1-
Soundigital-
Stetsom-
Cactus Sound 7kw-
Atomic 7000.1-
Feel free to correct the models I have listed I can be wrong.
Edited by pstone11
DAT 8.1-
Soundigital-
Stetsom-
Cactus Sound 7kw-
Atomic 7000.1-
Not sure why DAT is on your list when you said Sundown was over priced, so is DAT.
Stetsom and SD are great choices.
Cactus and Atomic is decent choices too.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
SounDigital 8000.1 without question would be my first choice... I did some testing with them and was very impressed with it for daily usage. Then when I just did TL testing it was burping like a .5db louder than 2 AB VFL400.1 @ .5ohm and was exactly the same as 2 VFL500.1 @ .5ohm each.
I have the entire test numbers around here somewhere if you're really interested in them.
Pioneer AVIC-N2
three 7k amps at .5 ohms?
hope you have TONS UPON TONS of batts and amps
x7897478923478293428934
you're talking about one metric assload of current pull.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
Well take sd off your list murilo tells me not to play music below 1ohm with the sd amps burbs are ok
Same goes for the Stetsoms IMO.
Why 0.5 ohms? The Stetsom and SD both do like 9kwrms++ at 1 ohm, what do you gain by going to 0.5 except a whole lot of heat.
Every one of those amps will pull over 1000A at 1 ohm and I wouldn't be surprised to see them pull 1200 or more amps at 0.5
But as I said, 0.5 = stupid.
EDIT: CS 7k and Atomic 7k are the same amp. And some people have issues with running them daily.
Edited by Boon
10.x volts fo' life!
the SD is a monster in a tiny package it will run without a problem all day long has good protection plenty of power at 1ohm no reason to push that amp any harder on a daily kinda deal with good voltage and batteries even with (decent) rise you will still see 7k or so your gonna need plenty of sub too oh and a bad ass box to handle that much power long story short almost hands down SD
