Can A kicker L7 Handle 2k watts?
Rainkey
Why not just check to see exactly what amp it is to be sure?? But if it says 1k rms then you will be just fine. 15" L7s can be run up to around 1500w daily as long as you're avoiding clipping.
Pioneer AVIC-N2
Try not to run it at full tilt for a long period. They can handle it but you best have a nose for it. The smell tell's you when it's time to bring it down. I run my two L7 at 1,200 per sub and they love it.
Alpine D900 head unit 7" flip out t.v
Kicker 6 1/2 components (front,rear)KS 6502
MB quart 3 1/2" in front A/C vent's (center channel)
DC Audio LVL 5 18" (pair) Custom ported box
Sundown 4500 at .5
Sundown 100.4
XS 3100 up front and a pair of XS 6500 in the rear.
1 17" Eiger Vision T.V
2 7" Eiger Vision T.V in Second row.
Dynomat Top to Bottom (foam in all halo beam's)
DC Eng Alt 260SP and a 400SP dual set up.
big 3
Sitting on 24"
If your neighbor don't complain it's not Loud!
So you best go fix your shit !!!!!!!!!!!!!!
if you have to ask...then i'm kinda scared about you even giving it even RMS power. shouldnt need to give it more to perform properly.
whats a dmm?? :/
lol why do it if your not sure period...
1000rms sub 1000rms amp its not really that hard to understand honestly
This is why he was saying what he was saying. :)
10501650_10203332501847103_1859383749711
Blown
my freind has 2 kicker l7's stapped to 4000 watts for comp. has had the subs for a pretty long time...almost 2 years or more. I think he turns the gain way down when not at comps.
"4000 watts max" or 4000rms
If its a 15 and up I say yes. If its a 12, then no, especially for daily. For some reason the 15 can handle more, which Im sure I read somewhere the 12's have a different build design from the larger sizes. Personally I wouldnt. However if you feeling lucky go ahead, but getting a recone for those L7s are hard business.
If you do decide set the gains correctly, here is the easiest way:
Turn the volume on the deck to your normal listening level, with the gain on the amp set to 0 so the subs arent playing, then slowly turn the gain up with the deck playing until it matches the speakers without drowning them out or sounding like crap. This is the easiest way to do it without getting into meters and formulas. Be careful though man...
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
it all depends in the box, there is a guy that ran a type r off 2000+ rms
when they are only rated for 750
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
Alot of retail companies use different builds on larger cone sizes which in terms usually means a better sub. Which is way alot of people can run double the power on type Rs or L7s. But a majority of them are 15s or larger, hence my statement. Also box sizes play a huge part in RMS handling
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
A 38 HZ Box
KICK ASS!
  • Who's Online   1 Member, 0 Anonymous, 433 Guests (See full list)
