Burb Build 4 18" Re X X X 150++ Daily Driver!
Big systems like this sure are a pain to build! I would have just done a flat wall, but I wouldnt have had enough room to get sufficient port area.
If you do a clamshell, Id suggest doing a vertical clamshell, because mounting a 70lb sub upside down is a 2-3 man job, and takes like 30 minutes to get 2 subs mounted.
Good luck with everything.
BUMMER!! how many cubes is the crx box going to be if you do it?
2002 Chevy Blazer 2 door
1-18" Fi BTL, 1 T2000.1bd, 8 ft box before displacement tuned to 33Hz, Big 3 done in 1/0
Havent been metered yet
i guess this also means that its not going to be ready for the show isnt it? :unsure:
I'm not sure if you've seen this gallery, but this is how pete of ttb did his odd-shaped port. You might have to/be able to do something similar.
http://www.hexibase.com/gallery/main.php?g...1&g2_page=3
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
well what i have in mind probably hasnt been seen much outside some hardcore spl setups but I am changing it to suit my needs as a daily driver that can hit the lanes also.........lets just say you will be able to see into the wall.........;)
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
