After a thankfully boring shift that I just got off, I took a few pics with my cell phone of the main wiring that leads to the rear cab area. The only section that I didnt take a pic of was where the main power comes in from a run of 2/0 cable, and the main "KILL" switch underneath the drivers seat.... I will get you all better pics on my next shift.
As far as power goes, the alt on this FORD 2006 ambulance is a LEACE NAVILLE (SP) and is damn large in size, unknown amperage though. Also, we have a drive shaft mounted 110v power generator so we can plug in normal "HOUSE" type electronics upto I think 4500watts........
Edited by newls1
I love my staffie :good:
So anti FACEBOOK it isn't even funny
how many batteries does the average ambulance have and what info can you give on them?
R.I.P!
(Nov-29-2009)
92 explorer
current build
We have 3 in ours, Ive seen some only have 1, but most have 2. We have the normal 2 under the hood, then 1 in a VENTED enclosure on the side of the box. All batteries are actually SHITTY batts. all 3 are different! and all are ACID or "wet" type batts.....
really shitty batts eh not even dry cell
and i take the 2 up front being its a diesel
and your alts are what 300+ amp?
R.I.P!
(Nov-29-2009)
92 explorer
current build
really wow is there any type of capacitor or anything if the batts cant hold up or backup power supply?
i'd imagen you'd need a back up or some thing
R.I.P!
(Nov-29-2009)
92 explorer
current build
holy bus bars! lol thats some crazy stuff. pics of the batts and alts?
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
I work in the electrical department at Peterbilt. Those large case alts are normally ~180-200 amp. Great cooling - They can run 200 amps for hours at a time with no problems. Also made to last MUCH longer than a normal car alt, since a Class 8 truck will normally run 100-120k miles per year.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 7042 Guests (See full list)
