Judging by your sig Op....you have a complex.....
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
pipe wrench or double nut that bish
R.I.P!
(Nov-29-2009)
92 explorer
current build
Yeah I'm gonna spray it and let it sit over night. I'll get that bitch out.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
Judging by your comment you have no useful information to add to this post. Maybe if you knew the story you wouldn't talk.
Vice grips can be your friend!
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
What up Ray, I guess your back from Vegas..I should have the hummer back in a few weeks, went a whole diff route, good luck with that alt, about time u decided to run them, I know u have had them for awhile
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
i did this recently with an intake bolt and snapped it off in the block, i used the proper size drill bit and drilled a pilot hole and used an easy out works like a charm.
Edited by maniac74
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
as long as you can get to the spot with a drill and bit. you may have to remove a lot of stuff to do that.
1998 jeep grand cherokee
future teardown and rebuild:
2-15.4 orion hcca's
sub amp undecided
2 sets of components
1-concept amp (mids/highs)
undecided h.o. alt
2-yellow tops
