+-------fuse--------------------------fuse-------battery
and yes you can ground to the chassis and an isolator only helps if you run your system with the engine off, which if you need two more batteries thats probably not a good idea
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Yes its fine to ground the second battery to the chasis.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
just a word of caution...stock alternators on a car arent meant to charge 2 batteries. L7's are power hungry so i'd look into a high output alt if i was u...adding a second battery does nothing but give u more playing time when the car is off...
Eclipse cd7000
agreed...
2007 Pontiac G6 on 20's
Current System-
Jensen VM-9312 in-dash
(1) Kicker 1500.1
(2) DD 1500 Series 12's
Running Knu Koncepts 1/0 wiring
145.6db- Floorboard
162.9db- Port
1983 Toyota Corolla Station Wagon (SPL Vehicle)
(Under Reconstruction)
Guest MegaloManiac
im sure it can handle its just going to act like 1 battery since he isnt using a diode. the batteries will draw off each other until they are both equal. I agree a HO alt will do more of a trick than 2 batteries. However the extra reserve will help cushion the blow easier.
Guest MegaloManiac
you should be fine...however i really think its borderline. Cause i remember a friend of mine had a 120A stock alt in his Tahoe with a single NINe1 and he said that it was just enough for that 1 amp to keep up with.
Edited by MegaloManiac
but heres the thing, youre pulling two different currents (1 from each amp) and only have one (mediocre) alt...i mean it still SHOULD work, but your power is really being supplied by the alt...
Eclipse cd7000
Yea, flinkster's making a good point but I'm sure he'll be fine with that alt. I did 2 Sundown 1500's in my buddy's explorer w/ a 135 amp alt. and it takes it like a champ. No dimming and he's always at a constant 13.1-13.8v. I used a stinger 800 up front and 2 of the new small stingers in the back. You may want to look into upgrading your starter battery as well. Look into this up front http://cgi.ebay.com/hc800-KINETIK-BATTERY-...VQQcmdZViewItem
And this in the rear http://cgi.ebay.com/hc1400-KINETIK-BATTERY...VQQcmdZViewItem
Wire them up parallel and you should be scraight. :)
New project in the works ;)
i thought the HC1400 was for the front and the HC800 was for the rear ........... that's how it suppose to go.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 4927 Guests (See full list)
