ccrider540 Posted January 13, 2010 Report Posted January 13, 2010 Im getting an orion hcca 12 and i wanted to know if anyone knew which boxes are better. Sealed boxes or ported boxes because iv had both and i think the ported is louder but ive heard its not. Someone said something about ported boxed having a high sound pressure level but not being louder. and i also heard that seal boxes are better for listening to music because u get a better response to low frequencies. if anyone can help it would be much appreciated. 1)Alpine CDA-117 1)hifonics brutus bxi 2610 1)hifonics zeus zxi6410 3)Alpine sps-600c 2)Fi BL d1 15s fully loaded
Team_DC-Derrick Posted January 13, 2010 Report Posted January 13, 2010 there is already a thread about this, but ill pull what i put up in that thread granted its copied from another website, its still good info Sealed Subwoofer Boxes The most common and versatile type of enclosure is sealed. This style enclosure is ideal for any application where space is going to be an issue. In some cases a sealed recommendation for subwoofer box will be half of what the ported recommendation is. They also have the advantage over ported and band pass enclosures in terms of overall sound clarity. A sealed subwoofer box will deliver a tight, clean and accurate bass response and have a flat frequency response curve. In general a sealed box will be for listeners looking for sound quality driven system that is clean across the entire frequency band.'' Vented & Ported Subwoofer Boxes Next up are ported or vented enclosures, “ported” & “vented” are synonymous, it just means the enclosure has a hole in it to let air escape. You know that guy you can hear from 2 blocks away? Well he is likely running ported box. This style enclosure will likely be about twice the size of a similar sealed box since the airspace inside the chamber is much larger. Ported enclosures are tuned to a certain frequency range which is determined by the port length, width and diameter. The port can be in several configurations such as rounded or a slot which is narrower and taller. Each subwoofer will have a specific frequency they are designed to run at for maximum output. Depending on what you plan to use the enclosure for it can be tuned to various frequency ranges by modifying the port. In general most competition SPL vehicles tune to high frequencies around 45Hz or higher. This setup would be designed for absolute maximum output but sacrificing a great deal of sound quality. A ported box tuned 25Hz will still allow your system to hit the ultra low bass notes while still keeping sealed like sound quality. The disadvantage is the enclosure will then have a fairly flat frequency range. And then the most common frequency range found usually in pre-built ported / vented enclosures is around 33 – 35Hz. At this frequency the enclosure will still deliver much more bass output than a sealed box but at the same type with still retain most of the sound quality. In other words you will get the best of both worlds with a ported box run at about 33Hz. Bandpass Subwoofer Boxes And last but not least are Bandpass enclosures. These are a hybrid box version and combine the features of a sealed and ported sub box into one enclosure. They are generally the hardest to build and design but offer some unique advantages. Bandpass enclosures are all about efficiency. How they work is a subwoofer or subwoofers in some cases are mounted inside a dual chambered box. One chamber is sealed and the other is ported / vented. The sound waves travel from the sealed subwoofer chamber though and out the port. This allows for a much deeper sounding bass and will be tuned to a narrow frequency band which creates a very aggressive sound. Not all subwoofers will work in bandpass enclosure so make sure you research or check the manual first. The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
SPL2K Posted January 13, 2010 Report Posted January 13, 2010 ported period. Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
cqtama Posted January 13, 2010 Report Posted January 13, 2010 double post, theres already many topics about this. just search R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x.
tlee2 Posted January 14, 2010 Report Posted January 14, 2010 Ported! 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
dwz Posted January 14, 2010 Report Posted January 14, 2010 In general most competition SPL vehicles tune to high frequencies around 45Hz or higher. This setup would be designed for absolute maximum output but sacrificing a great deal of sound quality. A ported box tuned 25Hz will still allow your system to hit the ultra low bass notes while still keeping sealed like sound quality. The disadvantage is the enclosure will then have a fairly flat frequency range. And then the most common frequency range found usually in pre-built ported / vented enclosures is around 33 – 35Hz. At this frequency the enclosure will still deliver much more bass output than a sealed box but at the same type with still retain most of the sound quality. In other words you will get the best of both worlds with a ported box run at about 33Hz. Aren't most pre-fabricated enclosures tuned higher than normal? O_o From what I noticed, sealed enclosures can handle a wider range of frequencies whereas the ported enclosures are FLATTER. AKA it stays in a certain frequency range. I don't know where you got this from, but if there's anyone else reading this thread please double check it.
