ok guys need some opinions here this right here is my most recent setup
that box was around 15.5 cu ft tuned to 30hrz
the new design is the same set up but bigger do you guys see any thing wrong with this it is bigger and tuned a lil lower i like :hairtrick: :hairtrick: :hairtrick: these :rolleyes:
im open to ideas even areos if there better Thanks
Edited by Hypnotik DesignZ
Jensen 9511TS~For Sale
JL Audio 300/4~For Sale
JL Audio1000/1~For Sale
Mephis 6.5 componet sets front and rear
4 15" Fi Q's in a 16 cuft box tuned to 29hrz
The tuning is off, you forgot to check the slot port which brings down to 25.41hz.
No. You only click that if part of the box is acting as part of the port, for example most L shape ports.
How many batts do you have runnin that power and what size alt(s) do you have?
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
um the top and bottom of the port are the top and bottom of the box
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Ive got 2 220 amp alts, 4 optima yellow tops and one red top, 2 runs of 0 guage
Hey what Box Tuning Calculator is that?
Ur old system was crazy :hairtrick:
1998 Jeep TJ
(4)Rockford 6.5" Power Spks
(1)Rockford T1500-1bd
(1)Rockford T600-4bd
(2)Infinity Ref. 5.25"
(2)Memphis Tweeters
(2)Walmart Tweeters :P
- Jeep Jammer Probox Ported
(2)Probox 10" Subs
- Kicker 1/0 Wiring Kit
- Pioneer P710-BT Headunit
It's stickied to the top of the subwoofers/ enclosure party of the forum
I'd personally go with like 4ft3 per woofer, 2 12" aeros w/ like 140-160in^2 of port area, tuned to like 34hz... You will gain a good amount by bringing up your tuning some and still retain the brutal lows.
What is your voltage like with the yellow tops?? I'd guess that you'd see a nice gain if you were to upgrade your batts and build a proper enclosure with aeros.
Pioneer AVIC-N2
u need bracing in the box, so that will take up some volume and raise tuning
i would put ur displacement to .85-.9
when u add more volume its going to be more bottom heavy anyways, so i would actually raise ur tuning to maybe 31-32hz and even out ur output a bit more
and u need to click slot port... so back to the drawin board
