danny_c Posted January 19, 2010 Report Posted January 19, 2010 I have a newbie question for you seasoned vets. Im a using DC as an example because its easy to remember the names Lets say we have a level 4 subwoofer right, What would be the difference between running a 10" and a 12" all same specs and powered by the same amp. What would be the advantages and disadvantages? Which one would be louder? Any difference in the way they will hit bass? Trying to decide what size i need. If the 10" will hit just as hard as the 12"'s and take less space then why not run them , right?
HHR Ed Posted January 19, 2010 Report Posted January 19, 2010 I have a newbie question for you seasoned vets.Im a using DC as an example because its easy to remember the names Lets say we have a level 4 subwoofer right, What would be the difference between running a 10" and a 12" all same specs and powered by the same amp. What would be the advantages and disadvantages? Which one would be louder? Any difference in the way they will hit bass? Trying to decide what size i need. If the 10" will hit just as hard as the 12"'s and take less space then why not run them , right? 12" has more potential to be louder because of cone area. But it depends on the space you have available. If you sacrifice box quality and design to fit a larger sub, then output will suffer. From an audible standpoint, you will most likely never hear a difference between the 10 and 12. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
czman30 Posted January 19, 2010 Report Posted January 19, 2010 I have a newbie question for you seasoned vets.Im a using DC as an example because its easy to remember the names Lets say we have a level 4 subwoofer right, What would be the difference between running a 10" and a 12" all same specs and powered by the same amp. What would be the advantages and disadvantages? Which one would be louder? Any difference in the way they will hit bass? Trying to decide what size i need. If the 10" will hit just as hard as the 12"'s and take less space then why not run them , right? well the only difference would be that the 12 might be louder and the 12 moves more air than the 10 Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
tobio19 Posted January 19, 2010 Report Posted January 19, 2010 i may not be a seasoned vet but from previous knowledge the 12" will be louder becuase of the larger cone area so it will be deeper.... 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
kirill007 Posted January 19, 2010 Report Posted January 19, 2010 I have a newbie question for you seasoned vets.Im a using DC as an example because its easy to remember the names Lets say we have a level 4 subwoofer right, What would be the difference between running a 10" and a 12" all same specs and powered by the same amp. In theory should be louder. What would be the advantages and disadvantages? Which one would be louder? The 12 inch should be louder in theory Any difference in the way they will hit bass? No, no difference. Trying to decide what size i need. If the 10" will hit just as hard as the 12"'s and take less space then why not run them , right? 12 inch hits harder, but needs more airspace, always make sure you have enough airspace. Thinking is the root of all problems... You ALWAYS get what you pay for.
tlee2 Posted January 19, 2010 Report Posted January 19, 2010 a 10 in its recommended box size vs a 12 in its recommended box size tuned to the same frequency off the same power the 12 will be louder. there are other situations where the 10 would be louder it all depends on the setup. 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
Neo_frog Posted January 19, 2010 Report Posted January 19, 2010 You really need to check the specs to get an idea. The resonant frequency of a 10 is a little higher than the 12 (using the example). So using the same box tuning for both will yield a slightly higher frequency response. Most likely it won't be noticible to your ear. It moves more air so the 12 will generally be "louder" on the same amp. Your biggest issue will be space. If you have the space to do the 12 over the 10, then do it. Chances are, the 12 will also have better power handling than the 10. Most of what ppl will answer about this is theory. You never know the facts until you try it. I vote 12. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
