Tip of lug nuts broke off on lug bolt Help!!!!
you would have had to take the rotor off or you did?
after lookin at it after i took it of it had no place for the studs to pop out since it had that shield behind it ill take pic when i get home just for all that never had never seen workings behind the brakes!!
GREAT! hahaha hope you still have money for lunch!
lol good thing they was buyin us lunch today at work lmao
I know a lil about everything so dont call me Mr. Know it All.
I'm not getting what the solution was. When you said the rim was loose, was it because the broken lugs worked themselves loose and you were able to take them off?
OR
Did you take the rotor off?
97 Maxima SE
Bunch of shit going in, check out the build
that^^^ im still kinda confused... why do the lugs need to pop out?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Problem - heads of lugs ripped off stud leaving only threads on the studs deep down in the rim where no tool could get in there to remove without damaging the rim.
solution attempts
kickin the wheel =fail
using a large gear puller = fail
taking it to tire shops = they dont know shit
now having those attemps fail especially the gear puller (pretty sure u guys know how those work) i thought it was on there for good until i had to break rotor or rim so i drove on it like nothing with 1 lug on it cuz thats all that would go on far enough. the driving made things vibrate which causes friction and since the wheel had nothing holding it back i.e lug cept for 1 wheel vibrated and shook loose and moved far enough to break the threads that was holdin it on. took off the lug that i had put on there to loosened enough to remove it by hand. that stud that had the lug on it didnt move as much and didnt break all the way. this is where i took the rotor off and knocked out the troubled stud saving rim and rotor.
your fuckin crazy drivin around with your lug nuts loose!!
i know but i that was part of my thinking process if a week of rollin around didnt break sumthing that meant i didnt need 24s on here!!
LOL I knew no tire shop will mess with that especially somebody like discount...
I woulda had to go the drill route... ya that sucks bad.....
Glad it worked out!
thanks man
